Thank you for those pictures. So it looks like the fresh air intake tube passes through the exhaust area somehow? And it looks like the passage way leads up, from the area under the exhaust fan?This thread has some cutaway pictures (post #6) from another Hearth member of the exhaust passages you are trying to clean (it's from a different St Croix model, but the construction looks very similar to your stove)
how do I get my st. croix scf-50 running optimally
I recently purchased a st. croix SCF-50 furnance and I'm trying to get it working to its full potential. I'm not all that familiar with wood pellet furnaces, so it is difficult for me to judge if it is giving out the full heat it can. I've tried adjusting the dampers but don't see a lot of...www.hearth.com
From those pictures, I would guess that it is plugged the most on the sides of the tube bringing the intake air to the burn pot (pictures 2&3).
I would try cleaning on both sides of that tube (I know, not an easy task, but might be doable with something like a metal coat hanger).
I cant get a chisel in there because of the angle. Ive been using a thin saw blade, but man are my hands a mess!I’ve used a long chisel to get at some of them I’ve had to deal with
If you can get it rigged up to work for now do it. Send me your blower. I will replace the bearings then put it back in and send the chinese blower back. Amazon takes anything back and it "just would not fit".Kind of. One fits inside, the other on the outside. Some of the screw holes line up, but I'm not sure about those 2 big ones.
View attachment 272436 View attachment 272437 View attachment 272438
Yes, it looks like the air intake tube passes through the exhaust channels, as a way to preheat the air going to the firepot. The small hole in the front may be covered by a hole cap, like in the picture below (from a St. Croix pellet stove maintenance video). Does your stove have those?Thank you for those pictures. So it looks like the fresh air intake tube passes through the exhaust area somehow? And it looks like the passage way leads up, from the area under the exhaust fan?
But in the picture someone is sending a wire through from the front. I dont understand where that is on mine. No hole like that on mine.
Ooh, I hadnt thought of that. Like buying an outfit to wear once.If you can get it rigged up to work for now do it. Send me your blower. I will replace the bearings then put it back in and send the chinese blower back. Amazon takes anything back and it "just would not fit".
OMG...it does! I never noticed those before. Jeez, have to wait for it to cool now.Yes, it looks like the air intake tube passes through the exhaust channels, as a way to preheat the air going to the firepot. The small hole in the front may be covered by a hole cap, like in the picture below (from a St. Croix pellet stove maintenance video). Does your stove have those?
I would let it keep burning for now. But try using a wire down through those holes the next time you have it apart to try to knock some of the crud down to the exhaust blower hole.OMG...it does! I never noticed those before. Jeez, have to wait for it to cool now.
Wish I had known about those last night when I had everything tore apart..or any of the other times I had it tore apart.
I just put everything back together!
Nope, no hair dryer yet. Im waiting to see if the burn pot still overflows.Yes it is an improvement. No hair dryer? Yet. I Have some ideas i want to see if i can make reality this weekend. Im thinking a flexable shaft with some nuts welded to it that you can put in a drill and shove down in there and beat the daylights out of the chit
That's what I'm thinking and was hoping, considering how long I spent on it. My hands look like Ive been changing oil on cars my whole life, I broke most of my nails off and I ruined 2 pairs of used to be white socks. But dammit, it's getting air now!Awesome it’s looking like your scraping helped!
If it works you should patent it. Call it a "NY Ssyko bustem' up". Or "the Miracle Auburn creosote buster".Yes it is an improvement. No hair dryer? Yet. I Have some ideas i want to see if i can make reality this weekend. Im thinking a flexable shaft with some nuts welded to it that you can put in a drill and shove down in there and beat the daylights out of the chit
RXwoman1961-NYSsyko Creosote Buster +If it works you should patent it. Call it a "NY Ssyko bustem' up". Or "the Miracle Auburn creosote buster".
Whatcha' think?
Too long? How about " RXSsyko formula '61 creo-crusher!" Or "Ssyko RX 61. Your prescription for a clogged stove!"RXwoman1961-NYSsyko Creosote Buster +
Wound probably be easier to double nut the nuts and lock them on. No fusion required. Why do I think the original owners was tickled you cam along and bought it. BTW what did you pay for it, if it's not too personal to ask?Yes it is an improvement. No hair dryer? Yet. I Have some ideas i want to see if i can make reality this weekend. Im thinking a flexable shaft with some nuts welded to it that you can put in a drill and shove down in there and beat the daylights out of the chit
Got it. Will do.If it burned out leave damper open and raise the heat level. Send some heat into the attic lol
I started looking for a pellet stove in July.Wound probably be easier to double nut the nuts and lock them on. No fusion required. Why do I think the original owners was tickled you cam along and bought it. BTW what did you pay for it, if it's not too personal to ask?
In reality he should have paid you for taking it. He knew pretty much what the issues were.
19 here and windy and the corn burner is doing what it's supposed to do, incinerate corn. House is maintaining 71 and 53% RH, but she's working pretty hard. I have it in notch 5 presently. Much above notch 5 and it goes into overheat. it will only run so hard and then the over temp snap disc ends the program. I do run a custom algorithm so in reality, notch 5 is probably pedal to the metal anyway.
I may, this summer, take it apart physically and open up the HX area for more air flow and add a second or a larger CFM room air blower to up the CFM and then I could get past notch 5 without an overheat scenario.
We've ALL learned a lot about your stove! LOL Knowledge is freedom, nobody can take that from you.Yes it was a turd but look at the polishing you’ve done so far and how much YOU have learned about your stove!! Hell look how much i have learned about your stove lol.
