I let it go out as I needed to run a few errands and I dont dare leave it unattended.yeah i searched all my know spots and some i don't usually go to $80ish is actually alot better than the going $149 and up. maybe we can walk ya through a bearing change off season..
hows the fire looking i need to see fiiiiire
Fireyeah i searched all my know spots and some i don't usually go to $80ish is actually alot better than the going $149 and up. maybe we can walk ya through a bearing change off season..
How loud is that blower ? Are there bearings in there or bushings ?
St. Croix Greenfield, Lancaster, Prescott EX/EXL Blower Fan Motor, 80P20003-R | eBay
Prescott EXL - 2004 to Current. Greenfield - 2004 to Current. Prescott EX / EXP - 2004 to Current. Lancaster - 2004 to Current. Convection Blower, Distribution Fan Motor Assembly. Pellethead Smokin Po Boy.www.ebay.com
For some reason I cant upload video. Im gonna' try again in the AM.Fire
By golly this thing gets HOT.
I ordered the fan from Amazon and bearings as well. Theyre only like $4.50 each.
Seems like I have to keep the damper open or pellets pile up and only blacken.
Rx, Remember it does have a live fire 6" from the doorGood to know! Thank you.
5 minutes may be a stretch. I think it may be 3 minutes.Ive been following! RX is a trooperProgress is being made. I would say to start it with the damper closed a little then open it as the feed level steps up. There is a approx. 5 min delay between steps. So if it is on 1 and you want it on 4, it will take approx. 20 min. to step up to 4. That is built in for corn burning. Corn does not like sudden change. Basically as much air as it will take and still keep up with feed. Ssyko, you probably already know that, but trying to throw so info out there in case it may help.
Once the stove is burned out and breathing properly I can help you to set the draft damper that will burn good on 1-3 and decent on 4. The St Croix dont like 5 much. it is basically get a clean burn on 1 and the sep up in fan speed compensates as you raise setting. But now of course it takes manual manipulation to keep it goingopen the damper more till the fire looks like its almost a blowtorch. Its going to be adjusted everytime the heat range is changed. More fule more air, less fuel less air.
Bearing pressed on the shaftsHow loud is that blower ? Are there bearings in there or bushings ?
I have replaced the bearings this blower a few times. If you send it to me I will gladly install bearings and send it back. I use a brass nipple to tap the bearing back in place with out getting into the plastic covers. Getting the squirell cages out is kind of a pain but doable . They are just "pressed on to the shaft endsI let it go out as I needed to run a few errands and I dont dare leave it unattended.
I ordered the fan from Amazon and bearings as well. Theyre only like $4.50 each. Maybe I can dink around with the old fan when I'm snowed in.
We've had an unusually mild winter...knock on wood... But that can change in the blink of an eye.
Nebraska, if you don't like the weather, wait an hour...it'll change.
Do keep in mind that the bearings in the distribution fan are sealed but, not hermetically sealed, they just have a dust seal, which, allows fine dust to eventually enter and dry them out and they fail (which is why yours are noisy) and the need oiled yearly, a few drops of 3-1 oil. The alternative is bearing replacement or a new fan assembly. Better than oil light bearings but still not perfect.How loud is that blower ? Are there bearings in there or bushings ?
Oh. I been using paper towels. Your idea sounds better, and cheaper!You'll always get some fly ash deposits on the view glass no matter what you do. Again ,like I tell everyone (and no one seems to listen), just take a cheap NATURAL BRISTLE paint brush (I use a 1" wide trim brush) and brush the ash off the glass. I do that a couple times a day usually.
Whatever you do, makes sure it's not a POLY BRISTLE' brush as it will melt to the view glass and make a helluva mess. I do mine when it running and mine runs 24-7 unless I'm cleaning it which, in my case is every 4 days because I burn corn and corn makes a ton of ash.
You can get a 10 bag of them at Harbor Freight for 5 bucks.
Yeah, it's not doing that well yet.When a St Croix is breathing correctly this is the type of ash you should have burning straight corn. I just did a full cleaning and leaf blower on it for the first time this season
View attachment 271970View attachment 271971
That stove is filthy...........When a St Croix is breathing correctly this is the type of ash you should have burning straight corn. I just did a full cleaning and leaf blower on it for the first time this season
