Get a refrigerator coil brush.
https://www.supplyhouse.com/Schaefe...8svRBbLbkASH-0dYMJYG8ucfPp_74sQRoCYCIQAvD_BwE.
And a cheap leaf blower to suck out the exhaust with the front door open and hook vac switch back up. You can light it and check it out in the garage. Get a piece of aluminum dryer vent for a temporary flue to get the exhaust outside and test it outside. If all your motors run and sound good, Youi just need to clean the 2 places no one knows about. with the brush and a leaf blower to suck exhaust out, You canhave it running like a champ in 30 min.
I don't have a garage and after what I went through to set here, I'm not moving it too far.
But I did disconnect it from stove pipe and used my blow dryer (I dont own a leaf blower) and my vaccuum cleaner. It blew a tiny bit of ash forward. Ive cleaned up inside the cleanout doors and I can see my wire swinging around up at the top near the heat exchangers, nothing more comes down.
This stove rode home face down on a dolly, you'd think any loose ash would have dislodged. So nothing is blocking the exhaust, the air intake is open. I repaced the door gasket, twice (first one was too big!) and the dollar test is better, I at least have resistance now.
Turn the stove on, exhaust fan runs for a minute, then shuts off and #2 light blinks again. I checked the vaccuum hose. Looks good. The exhaust fan looks new, like it was just replaces as well.
I sucked on the old vaccuum switch and it clicked. Thought maybe it was still good so I tried hooking it up again. Same thing happened.
I also just noticed the new vaccuum switch has 2 nipples!
So which is the one to hook up?
Also maybe I'm putting the wires wrong?
Who ever worked on this last put tape on the wires..I'm assuming to mark positive leads?
Which prong does the positive wire go to?
This stove is making me crazy. It will be July again by the time (if) I can make it run! HELP.
![How to burn wood pellets in 2006 Auburn corn burner How to burn wood pellets in 2006 Auburn corn burner](https://www.hearth.com/talk/data/attachments/269/269565-3067f4826cebef200580f9f3cb6148ee.jpg)
