Rhonemas said:Anyone trying to do E/W, the BIGGEST secret and I'm surprised they didn't show this in the video is simply to make sure you push your ashes to the sides before loading so there's a tunnel under the front splits so air can get into the center/back. My unit can take 14" N/S logs, or 24" E/W and I love wide logs they stack extremely high.
Ahh! I'm on the right track then. This morning I tried another E-W load and the back log from last night was still barely intact enough to move it to one side, so I did. So I basically have the coals all up front and a something on the side to lift up one side of the splits for better air. It still seems like I am loading more wood than I did previously, but based on the amount of coals I had left, I did get a longer burn. Come to think of it, the house was a couple of degrees warmer too. I guess it makes sense
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
FYI, I've only been burning my new stove since the first week of November, so I am still learning the nuances. The technique I had settled in on so far was to rake the coals into a N-S bank in the middle and put a small 2-3" round on either side of the coals with a couple of inches between each small round and the side firebrick. I would kind of sandwich in the coals and then poke them if necessary to allow air flow right down the bottom middle. Next I would lay 2 or 3 larger splits or rounds E-W on top of the coals/rounds. Last, I would place an another layer on top consisting of 2 to 3 small (1-2") rounds or splits laid N-W, or other miscellaneous scraps. I would leave the door open an inch or two until the fire gets going good and then just gently close the door without clamping. Its surprising how much air still gets in this way. Once the stove top reaches approximately 300 I clamp the door. Damper down to 1/2 at 400 to 500, then down to 1/4 or less a few minutes later at around 600. Stove temps usually max out 600 to 750 this way with enough coals left after 8 to 10 hours to restart easily with little or no kindling and a little blowing on the coals. Nice clean firebox in the morning too, though it does smolder for a few minutes when I start. Thats the opposite of what I noticed this morning, BTW. With last night's E-W burn there was no smoke or smoldering at startup, but there was a slight darkish residue in the firebox instead of the nice bright firebrick and baffles.
Sorry for the long post, sometimes its hard to stop!
