I have a 1927 bungalow with a fireplace. There is a very simple insert consisting of hollow tubes which serve as the wood rack. There is a blower which circulates the hot air into the room. We've used the fireplace every winter for over 30 years. The chimney is now in disrepair and I would like to install a chimney liner but keep my current insert. I also plan to replace the chimney crown and repair the brick above the exterior roofline. The problem is that the simple blower insert does not have a top to connect to the chimney liner. What I'm thinking of doing is building a sheet metal liner inside the firebox with a top to accomodate a liner. Does anyone have experience with that? I'd like to know if it's feasible, what type of sheet metal to use, and how far back in the top I should make the hole for the chimney liner.
I plan to install a top damper and would like recommendations on that as well as the best kind of liner, 4, 5, 6 inch? Smooth wall, insulated?
Thank you for any insight.
![[Hearth.com] How to build an insert for a chimney liner [Hearth.com] How to build an insert for a chimney liner](https://www.hearth.com/talk/data/attachments/320/320914-70d8eb44e47d9b6cc02d90aaa20859c0.jpg?hash=DPAZ8G5BQJ)
![[Hearth.com] How to build an insert for a chimney liner [Hearth.com] How to build an insert for a chimney liner](https://www.hearth.com/talk/data/attachments/320/320915-4f2fe78dd0209803778553b91c09b2af.jpg?hash=GwLW1PFAcU)
![[Hearth.com] How to build an insert for a chimney liner [Hearth.com] How to build an insert for a chimney liner](https://www.hearth.com/talk/data/attachments/320/320916-84b5568084e447cf4719798b6ed6615c.jpg?hash=CQccaWjxTh)
![[Hearth.com] How to build an insert for a chimney liner [Hearth.com] How to build an insert for a chimney liner](https://www.hearth.com/talk/data/attachments/320/320917-34a3c1a5673e220b8542c4892a60a53a.jpg?hash=JSQGjawHmR)
