haha[quote=tickbitty]We did this whole backup battery thing for our sump pump in the basement. Only to find that it isn't powerful enough for the pump, so we had to buy a littler backup pump that uses a garden hose to pump it out. Only to find that when the water is that bad in the basement, that pump won't do it and will run constantly till the battery runs out. Generator a much better idea for us too! I had hoped that the backup system would help for the stove blower at least, but sounds like it's not that good for that either! Good thing we got an insert that sits so far out of the chimney, we will get a lot of heat out of it anyway.[/quote]
How about this, [url]http://s7d5.scene7.com/is/image/FisheriesSupply/9154_Rul_24_PPM?wid=450&hei=450[/url]
runs on 12V DC and doesn't draw a whole lot of amps. It's got a float switch so it will turn on and off on its own.
maverick06 said:before the wide world rip[s that post apart. The double male cord is a safety concern and powering your house through one is illegal. BUT since you have a small generator, I ASSUME that th plan here is there are a pair of outlets (one inside and one outside, NOT powered) then you can plug the blower into one and the generator into the other.
Now, you can sort of do this with just your male-male cord and just the house circuitry... its illegal... and i dont know what would happen to the 220 side of the circuitry.... I would like to know. Obviously i am not using this method. I just have a circuit breaker and a lot of extension cords.
He had the outlets isolated from the house wiring and was just used for the blower, sounds like he new what he was doing.moosetrek said:maverick06 said:before the wide world rip[s that post apart. The double male cord is a safety concern and powering your house through one is illegal. BUT since you have a small generator, I ASSUME that th plan here is there are a pair of outlets (one inside and one outside, NOT powered) then you can plug the blower into one and the generator into the other.
Not sure it's necessarily illegal depending on the OPs location. Not smart, but our electric co simply said make sure that there's redundant isolation from the grid if we want to hook up a generator. Maybe against code though...
Nothing would happen b/c you would prudently shut breakers on 220V circuits first; you'd effectively power only one leg of your panel. More importantly, the amperage produced by the generator may exceed that of the 12-14 gauge wiring to the outlet, overheating the outlet and/or wiring.
I dont like them either, I wire my gen direct into the fuse block on the pole, I have a fuse block that you can remove so not kill any lineman working on a pole some where.maverick06 said:agreed... I was just trying to clarify that. Man have I seen some %^&storms; on other forums about those male-male plugs.
What 2 stroke gen?velvetfoot said:What are those little 2-stroke gennys like?
Noise and smokey, or not so bad?
I had no idea they made a 2 stroke gen, learn something new every day.velvetfoot said:"This is the generator I use.
http://www.northerntool.com/shop/tools/product_200313480_200313480 "
2 stroke-dirty emisions maybe.moosetrek said:Can't be shipped to CA... Wonder why?
