E
elkimmeg
Guest
I get a lot of e-mails and try to answer them, plus the private messages here. Somethmes it may take a day or so.
well the first engineer that certified these chimneys purgered himself. When called to the mat he admitted to having never
visiting the site and never inspecting them I let him off the hook and allow him to withdraw his certifying letter. I hoped he learned an inportant lesson. His alternatives was to withdraw or I was taking him to the state review board. Once he found out I had drilled into the hollow core blocks and that the chimneys were being built un supervised by illegals he really want no part of the responsibility.
He knew that I knew he screwed up. He now realized I was questioning his stamp. Apparently the mason brought him a set of plans t certified to be correct. The mason never told him the real reason he was requesting review.
I shut down the job again
Another conference with the mason and the supervising construction company. There were two alternatives offered,, either tear them down and reconstruct the to code. or hire another engineering firm to certify them and wittness the hollow core blocks being filled and that I also see part of the process. He opted to go the certification route. All my concerns are fully documented and part of public record as is the next engineering stamp. Legally I have done my job. I can accept the stamp and move on.
BUTT
!! I uncovered another life safety issue with one of the fireplaces. Yesterday I was there doing a rough mechanical Inspection.
I look into the fire box onone fireplace and discovered the only 2" of fire brick separates the top of the fire box and the wood combustiable header. Code is 12" of solid masonry or 8" with fire brick. Making matters worse is the damper is set to the furthest back position. the fire box has curbature towards the from which direct the exhaust an heat away from the damper and right at the 2" fire bricks and wood header above.
I now face two choices ignore it and hide behind the engineering stamp or require it to be brought up to code. Moving the massive header up and filling the area above with the required dept of solid masonry. What would you do? I admitt this situation is wearing me down. This is a prime example of why I take the stand of illegals constructing fire boxes un supervised un licenced. I have never had this much grief. The mason's contract for this home is $850,000. All cultured stone facings. One would think there was enought money alloted to use solid blocks. I mean for $135 more it could have been done correctly. The home final price will approach 3 mill. The 2 other fireplaces are built the same way with the same damper locations and same curbature but do have enough masonry above them to combustiables. All have smoke flow design problems, but they are not code enforceable
BUTT
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
