Como said:
I have a special vac for the ashes and I do just turn the T Stat down and vac, this is also when I pull the rod a couple of times.
The burn pot, where the holes are, there is nothing to scrape? It just falls through.
Maybe the pellets I am using. I will do the rest as you mention.
just be careful, m8.
i have an ash vac too. and they are made "for cold ash only" as stated by a sticker on mine. i'm definitely going against recommendations even vacuuming warm ash.
seems like you could go through these steps even faster than me if you're not doing the burnpot.
i also notice that the inlet in my vacuum directs the incoming ash to the wall of the canister.
i suppose if the incoming ash were to hit the filter first, the chances of mishap would be slightly increased.
but as it is, i know there aren't embers by the time i vac.
just be sure of that.
there is usually a little carbon "scale" in my burnpot.
nothing more than a thin layer in spots on the bottom faces.
it's not a big build up and doesn't block the holes.
it's probably something i could ignore. but it's just part of my routine as it chips off easier when hot.
SO AT THE RISK OF SOUNDING LIKE A MOTHER HEN- YOUR STOVE OR PELLETS OR OTHER FACTORS COULD BE DIFFERENT THAN IN MY CASE.
DO HOT CLEANING AT YOUR OWN RISK. AND BE FRACKING CAREFUL!
no burn holes in filter cover after 3 months vacuuming nearly every day. but it only takes once.
(broken image removed) (broken image removed)
replying to your following post here to keep from making another post.
i seem to be very post happy today.
i kind of judged you had things under control.
and i added my warning for anybody reading my suggestions. as i have no idea if other stoves leave hotter and more embers in the firebox.
i would hate to lead anyone even less experienced than me down a path that made them complacent and did harm to them.
