Ah, I can't keep up. 1, 4, soon to be more.When I read it I saw 4 posts, she must of done 4 really quick!!
How can insulating your liner change the way your stove burns? How could it burn longer?
Ah my woman and her first post. Welcome.
What 67 is not warm enough for you?
Lets see how cold it gets, then we can adjust so.
I'll take a shot by saying it creates a better draft from being warmer so it allows the stove to be dialed down more, makes for better secondaries and the fire won't smolder when dialed down. Obviously some chimney's will draft great no matter what due to height but I could see a 15' chimney benefiting from insulation.
OK im just askin this cause Im curious and don't think in my mind like your saying. I may be wrong though?? I DO agree a warmer chimney should create better draft. BUT when turning the air down lower do you REALLY increase your burn time? Your dialing air down for a given draft to create a long burn, but if your draft is not as strong you leave the air open a bit more,BUT its not sucking in any more air into the stove at a similar burn rate because the draft is slower so its not sucking in as much air as the stove with a strong draft at that same setting??
Confused you yet or did I explain my thought on this enough for you to understand where im coming from?
I been married a long time......my advise, put more wood on hogAh my woman and her first post. Welcome.
Hard question to answer. Individual setups are all different. My new Hampton has just over the 12 ft minimum chimney at my elevation. It drafts great. In fact, I put a pipe damper in the double wall stove pipe for emergencies and now find on cold windy nights with a full load, I can get the load settled in with secondaries and close the pipe damper all the way. Go figure...my chimney is 13 feet total.No clue, just took a shot. I had never heard it burning less wood before reading Ed's post so I just went with it. My thinking was on a non cat the better the secondaries with less active flames on the wood the longer the load would last since you get better secondaries with a better draft. Of course it's a fine line between the perfect draft, too much or not enough. I was thinking a 15' chimney with insulation or not, my 30' would draft fine with or without. My experience with a non cat and a good draft was not good so I now have a cat stove.
I figured someone smart would answer by now, I was hoping to drum up the answer for Ed.![]()
67 with a wood stove sounds cold. Even one the lowest setting my place is 77 with 30 Deg outside,and i only got 1 stove at home and its in the the basement.Ah my woman and her first post. Welcome.
That is if your near the stove!! But my bedroom on warm nights is just 70F and will normally be in the 67 range. Cold nights its close to 61 in the mourning. But i am as far away from the stove as you could get and there is no wall insulation in my house. I could not sleep with it 75 in my bedroom, unless i just use a sheet and small blanket maybe? But the point is that everyones house is different as well as thier sleeping conditions.67 with a wood stove sounds cold. Even one the lowest setting my place is 77 with 30 Deg outside,and i only got 1 stove at home and its in the the basement.
It all depends on the house size and outside temp.67 with a wood stove sounds cold. Even one the lowest setting my place is 77 with 30 Deg outside,and i only got 1 stove at home and its in the the basement.
My bedroom stays about 70 and its 2 floors up from the stove. I do need 2 fans to circulate the air or my stove floor would be 90 and the next 2 floors up much colder.That is if your near the stove!! But my bedroom on warm nights is just 70F and will normally be in the 67 range. Cold nights its close to 61 in the mourning. But i am as far away from the stove as you could get and there is no wall insulation in my house. I could not sleep with it 75 in my bedroom, unless i just use a sheet and small blanket maybe? But the point is that everyones house is different as well as thier sleeping conditions.
Your insert is in the basement?It all depends on the house size and outside temp.
No stove is going to heat this place at 2600sf (not including the basement)from the basement.
When it is single digits out with 0 or below wind chill, what we wake up to, is what we have. 65 this morning when I got up.
At 30 degrees outside, yeah sure I can have this place around 77 downstairs, upstairs even warmer, but that is too damn hot for me.
The insert is doing just fine.
For some reason i can get the house a lot hotter with the wood stove rated at 75000 BTUS than the coal stoker boiler rated at 90000 BTs. So it seems either the wood stove is under rated or vice versa.
It is crap, this year ,a lot of ash for not so much heat. THere is one place that always has good stuff,but it gets so hot it cracks the grate every year without fail. My wood is 3 year seasoned oak ,premium stuff.Maybe your coal isn't as well seasoned as it should be ha!![]()
