Carl said:[
(broken image removed)
That tractor looks aroundabout the same size as my JD2520 and Im going to be moving (hopefully, I've got it all set to jack up) a shed 10x14 that looks quite a bit like that one about 50 feet.
Carl said:[
billb3 said:Carl said:[
mayhem said:You'd probably never bend your axle, but I could see severe overloading snapping your springs. In order to do that to my truck I would probably have to put 3 or 4 tons in the bed, which I would never do.
Just in case you think I'm overloading my truck though, the 3/4 ton rating does not mean its rated to hold a 1500lb load...maybe it did 50 years ago, but not anymore...its just a GVWR (Gross Vehicle Weight Rating) classification...which is how much the truck is rated to weigh in total...truck, fluids, passengers and cargo. 3/4 ton menas 8600lb GVWR, so 8600lb - my 5600lb truck gives me about 3000lb safe and properly carrying capacity. 3/4 HD is 9200lb, 1 ton is 9600lb and so on. So my truck hauling 3000lb of whatever I put in the bed is right theer at the upper limit of its rated (and legal) capacity.
Other factors also apply such as the GAWR of each axle, but you get the idea.
burntime said:Anyone have some military axles that will fit my ranger?
Highbeam said:mayhem said:You'd probably never bend your axle, but I could see severe overloading snapping your springs. In order to do that to my truck I would probably have to put 3 or 4 tons in the bed, which I would never do.
So what makes you think that your truck weighs 5600 lbs, have you actually weighed it? I have weighed my weenie half ton on several occasions and depending on fuel load run 5800 lbs with no cargo. The folks with those noce big 2500s from GM are reporting 7000 lb empty weights.
I have bent my axles. I also ruined a pinion bearing in my truck's rear end and when the men were rebuilding the axle they informed me that the axle tubes had been bent due to overloading but nod badly enough to trash the assembly. Between the pinion and bent tubes they concluded that I needed a much bigger truck.
Highbeam said:...Seriously, that's only two healthy ladies in the bed as cargo.
Highbeam said:So what makes you think that your truck weighs 5600 lbs, have you actually weighed it? I have weighed my weenie half ton on several occasions and depending on fuel load run 5800 lbs with no cargo. The folks with those noce big 2500s from GM are reporting 7000 lb empty weights. This still leaves a healthy 1600 lbs of cargo capacity for you though. Oddly, a ford ranger or toyota minitruck spec out to 1500 lbs of payload capacity as well. Properly spec'd (read a rare truck) you can get your curb weight down to almost what GM lists for the truck. We're talking 2wd, reg cab, small gas engine, etc.
TGun9590 said:Did the same with my Tundra this week end. She can pull the load O.K. but I'm not sure how many more loads the leaf springs can take. I snapped one on my last truck. :bug:
