Same for me. Only use propane if we need to leave for more than a day.Good point. I have propane for a backup however 95% of my heating is done with firewood.
that sucks...I burned about 2.5 cords and roughly 500 gal. of propane this winter. Ran out of seasoned wood, so been on the furnace for about a month and a half now.
yup, it kinda does, but we will be in a better situation next winter i think.that sucks...
My house isn't real old (1978), but it certainly isn't to today's standards. I burn from usually the end of Oct thru early May. Our hardwood is definitely the biggest difference. Unless it's super cold, I only make a "big" fire for overnight and make smaller fires and burn woodchips during the day (I'm generally around). Stove is still producing some heat and has plenty of coals 8-10 hours after an overnight fire...and mine is secondary not a catalyst.I’m always surprised how you eastern folks in your old houses and frigid cold temperatures use so very little fuel to heat your homes. Your stoves are at least as big. Your fuel is more dense and cold season shorter I guess must be the reasons.
Ok, now THAT'S FUNNY! Let me get my bathroom scale out every time I haul wood into the house to burn...Now if everyone weighed their wood prior to loading and posted their cumulative weights instead of volumes, we wouldn't have this disconnect. It's useless to compare volumes of different species.
I'll go first....15,295 lbs. and 7,011 HDD's to date.![]()
But let me ask you this: IF assuming the same moisture content, will 25lbs of pine give as much usable heat as 25lbs of oak (or whatever random weight you think your stove will hold of the oak)? I say no because the volume of the pine will be twice as much and the burn time half as long as the oak resulting in loading the stove twice and having to reheat the system...![]()
Weighing the fuel would be more meaningful but I just can't do it. I already get ridiculed for logging each gallon of fuel in my pickup, miles, mpg, and fuel cost.
When the house starts to get cold, I put more wood in the stove...
I know all wood has the same BTU output by weight (which I learned on this site - had no idea before), which is why I was very specific about my parameters. It was intended to be tongue in cheek. Not many people outdo my OCD tendencies, but I think I found my match... Here in good ol' cheesehead country even!
