Dune said:
Older dryers drew 5800 watts. Newer ones draw 5000 watts.
Good info!
If correct, most of us should typically use between 2 and 6 kWh of electric energy per dryer load.
Depending upon one's electric power rates, this would then cost us anywhere between 0.1 and 1.0 US $.
Now comes the kicker, though. Unless I found the wrong numbers it looks as if the typical dryer blower has a 500-1500 cfm capacity. So, let's assume we may blow as much as 50,000 cubic feet of warm house air into the outside world per (big) dryer load. This equals about 1,350 cubic meter, or roughly 1,350 kilograms of air.
On a cold day, we may have to heat the replacement air by 40F or so. It takes about 1 kiloJoule to heat 1 kg of air by 1 degree Kelvin.
Unless I screwed up the math, I am finding that reheating all that air by 40 deg F will cost about 8 kWh (~ 27,000 BTU) , or so.....
Please Lord, let me be wrong...... (I am in a bit of a hurry and don't have time to carefully check my calcs). However, if I am not, we may be paying more (on a cold day) to reheat all the air we blew off through that dryer than we are paying to run the dryer in the first place
In case you were thinking: "well we need to ventilate the house anyhow.....", let me point out that a 1,000 cfm dryer-type "home ventilator" blows at least 10 times more air than the recommended ventilation ("room air turnover") rates for your average 20,000 cubic feet home.
Moreover, few if any homes are wired in such a way that the forced home ventilation via the dryer is somehow subtracted from what the "whole house fan" is programmed to do every day......
Have fun!
Henk
