SolarAndWood said:jebatty said:The big 1000 gal radiator storage tank is pretty much just like that, absolutely even, consistent heat, without drafts, hot spots or cold spots, and no electrical power to make it work.
That is a pretty good argument for using cast iron radiators as well.
True as a general rule of thumb, although a tank offers much more radiant surface than a CI rad does, so the CI rad often needs hotter water than we really like in a wood system, but not in this application.... Given that the tank is there in the shop area, it seems to me like there is NO benefit to any other sort of heat distribution method besides JE's using the tank as a radiator... Any other method would add expense for materials and labor to install, and increased operating expenses for pumps and such, not to mention adding complexity.
If the tank was not located in the shop, then certainly the use of a unit heater and / or radiators would make sense as a way to heat an existing structure, but that is not what we are dealing with here...
From his description, the only thing I might change in JE's setup is to make some sort of hinged panel setup to make it easier to adjust the insulation coverage w/o needing to handle the insulation directly - less contact w/ potential itchies, and probably less wear and tear on the insulation itself - but this is a relatively minor deal...
Gooserider
