I clean mine out twice a year and after burning 4 tons of rather dusty Lignetics I removed about 1/2 cup each time so my Harman must be pushing most of the fines thru the auger.
Owner of a Harman P-38 (basement dweller) and an Englanders 25 PDVC (workshop garage) . They are totally different stoves but they work exactly as advertised and I like em both .
me too!
I have a P61A and I clean out the fines box every 2nd or 3rd cleaning...I do full clean every 7-10 days need it or not.. with a nut driver, loosen 2 screws and rear panel is off.Well I cleaned my fines box. I know I've only burned just short of a ton of pellets but I had to have a look in there. It was up to the shaft bottom in pellets and fines. I scooped out the pellets and vacced the fines. Did a half hearted job of it and fit the cover back on, figuring it wasn't all that full.. Is there more to that thing than that ? It looked like I could see over to the other side of the stove someplace through some channel inside there ( i know it wasn't really that far but it looked it). From what I've read what I did is about all that needs to be done. Retrospect is kicking in !! The stove is up and running now .
Mine is the same stove, P61a. There were quite a few pellets in there, some broken a few were not ( short ones). But more to the point , is that the only access that we have to be going through ? I'm glad I did it, any longer would start to get messy.I have a P61A and I clean out the fines box every 2nd or 3rd cleaning...I do full clean every 7-10 days need it or not.. with a nut driver, loosen 2 screws and rear panel is off.
the fines box for me has more broken pellets than fines....
prob cause I burn stove chows which are hot as haitii but some of the pellets can be a bit long..
[crunch]
I have seen fins so packed in the box that the auger will not turn and I have had to use an ice pick to break it up.Hello
I Found a Fines Box Full of Fines! Say that 5 times fast! LOL
First I found a P61-2 in Mint Condition! Is that a cream puff?
I was wondering if this was normal? Maybe it has not been cleaned in a few years?
Click pic to enlarge:
as far as other fines? yes..Mine is the same stove, P61a. There were quite a few pellets in there, some broken a few were not ( short ones). But more to the point , is that the only access that we have to be going through ? I'm glad I did it, any longer would start to get messy.
On another note, this was the third cleaning and the dirtiest I've seen the stove ( been burning a bunch of 1% ash pellets lately, plus I went 11 days this time. This time too it was time to dump the ash pan, it was 3/4 full. I had not dumped it previously. The stack pipe and ESP still look clean.
Ok thank's. Ya I pull that cover each time I clean, still haven't found a whole lot in there but this time the fan needed a brush job and vac.as far as other access, behind the Big ash pan is the exhaust fan which after you remove the cover there is a square opening[exhaust] which I usually use a bristle brush and clean out
the grey ash in there.. it's also where the EXP probe is so have to be carefull.. [u may already know about this]...
Excessive Ash]: I burn Energex premiums and Stove chows.. after burning the Chows I have usually double the ash content so it's normal depending on what u are burning...
also, there is not any spot in my stove that ash does not find and camp out....
I did pull the bottom cap off of my stack outside recently and had about half" of damp caked ash in the bottom of the cap but the rest of the pipe was clean. [pic left]Ok thank's. Ya I pull that cover each time I clean, still haven't found a whole lot in there but this time the fan needed a brush job and vac.
Me too, brushed it all down then. I pulled my cap ( Mine is inside the fireplace), found it empty.I did pull the bottom cap off of my stack outside recently and had about half" of damp caked ash in the bottom of the cap but the rest of the pipe was clean. [pic left]
as u know, when the stove shuts down, the exhaust fan will run sometimes for 40 minutes or so.
I take advantage of this and do the Ash brushing as this keeps the dust from entering our living room.
I think I learned a valuable lesson when cleaning and maybe why I had damp ash in the cap...Me too, brushed it all down then. I pulled my cap ( Mine is inside the fireplace), found it empty.
When i wanted to try all hardwood pellets I let the hopper runway down low and then scooped out a good part of what was left in there and couldn't get over all the fines/dust/sawdust that was collected with the low hopper pellets. I thought oh well and dumped in the hardwoods which teh stove burns great. But because of seeing all the fines I thought on the next cleaning I better pull the lid on the fines box. I found mostly pellets in there and some fines kind of stuck to things. As I said in an earlier post, this whole collection was up to the bottom of the shaft that resides in there, so maybe 1/2" deep or so ? Have burned just about a ton now. But some of of these pellets I've had have been super dusty, especially the Okanagan Premiums.Mid season cleaning at about 2 plus tons I got a tablespoon at most of fines. Things are tight enough even though pellets are a bit dusty to not worry about the fines box but at the end of season cleaning. Let the stove run out of pellets for the mid season cleaning to see if anything in hopper to worry about.
My Home Depot Stove Chows always show a bunch of fines at the top after I dump a bag in.. I get a thin flat cheapo paper plate and skim as much as I can from the top layer of pellets, holding the pellets, I tap the fines into a trash can and put the pellets back in the hopper. Usually the fines are all together in a small pile on top of the pellets.When i wanted to try all hardwood pellets I let the hopper runway down low and then scooped out a good part of what was left in there and couldn't get over all the fines/dust/sawdust that was collected with the low hopper pellets. I thought oh well and dumped in the hardwoods which teh stove burns great. But because of seeing all the fines I thought on the next cleaning I better pull the lid on the fines box. I found mostly pellets in there and some fines kind of stuck to things. As I said in an earlier post, this whole collection was up to the bottom of the shaft that resides in there, so maybe 1/2" deep or so ? Have burned just about a ton now. But some of of these pellets I've had have been super dusty, especially the Okanagan Premiums.
..[ the little tricks and tips ya come with out of expirimenting..]
