thatguy69
Went through 5-6 ton's heating with my vogelzang 5790 the past 2 years. Heating 1100 Sq ft single level ranch with no basement. This will be the first year with my Harman p61 and I'm hoping for better results
You should have far better heat control.Went through 5-6 ton's heating with my vogelzang 5790 the past 2 years. Heating 1100 Sq ft single level ranch with no basement. This will be the first year with my Harman p61 and I'm hoping for better results
Interesting to see what other burn. I have a 1300 sq ft home. I'm using about a bag a day... Since the start of the burn season I've got about 5 bags left on the first pallet so far....I didn't think that was too bad. This is my first year with a stove and wasn't sure what to expect
Sent from my SM-G930V using Tapatalk
Ussc 6041 second hand.... Paid $300 for it. Bought new in 2012 came with new board and auger motor. I jumped on it.What stove are you running?
Is corn better to burn?1/10th of a bag so far, I nly use pellets to get the corn burning.![]()
So far I've gone through about 2/3rd ton of corn, if that helps.
Yea this is my first year burning all electric running base boards were killing my bills. But I got a hell of a deal on pellets. I bout 6 tons for $26 a ton it was their last years stock and wanted them gone so I filled up my garage with them at that price and all is good. Only had like 10 bad bags out of 6 pallet loads.That's a good deal. I'll let Firepot and Bio and others answer the corn deal. I've burned a bit but not all season yet. I guess the main thing is that you get it cheaper then pellets. If so cheaper heat is good, Right? It is a little more work but if it's a lot cheaper than a ton of pellets then......
You can use the search also here. many discussions on burning corn here with Tips for it, Pros & Cons etc;
Ohio is the eastern area of the corn belt and if the conditions are right you should be able to buy corn for around $100/TIs corn better to burn?
For me it's a no brainer. I get mine from a farmer that has contracts all over the mid-west for delivery. He has his own dries, elevators and semi's to haul it. Extremely clean, dried to 12% or better. I pull under the chute, pull a lever, in two minutes I have a ton in my pickup. Get home vacuum it out into IBC totes for storage and am ready to go for the winter. It takes about 8 easy hours for the 30 mile round trip, vacuuming the corn. I could do it a lot faster, and do when the weather is cold or bad but I'm almost 60 so I can lolly gag around.Is corn better to burn?
Yea at the local tractor supply . they had a crap ton of it and put sign out for $26 I got all I could fit lol$26 bucks a ton is unreal. You basically got 6 tons for less than most pay for 1 ton. $26 a ton is the best score on pellets I've seen yet.
