etiger2007
I try to keep my stove top between 550-650. I have had the glowing top and the therm was pegged at 800, cutting the air down sooner cured this.
Good question. I have been using the highest temp I can find on the stove top as my referenceWhere are you measuring the temp? It's my understanding that for the IR we're supposed to be measuring temp at the outer, forward edges of the griddle top (the part on top that opens.) When I check there with my IR gun "normal" temps are 500-700. However when the corners are 550 the center of the griddle can easily be 750 and up, so it matters where you measure.......
When I have it fairly full and it gets away from me, shutting the air all of the way will not stop it from going nuclear. Since I started this thread I have been shutting it down sooner and it seems to help so far. In another thread someone referred to it as "the firey gates of hell". That about summarizes it. Secondaries going nuts and not slowing down no matter what I do at that point. All that said, everyone's advice of shutting down earlier seems to help avoid thatUnder 750F and all is good. Then bring it back down to the 550-650 range where it likes to cruise. The IR likes to have a couple of nice big splits and then fill in with what ever will fit. I load mine to the max on virtually every reload UNLESS I am trying to time the burn (like time it right for a nightly fill). The temps you reported don't even raise an eyebrow. Yes, time to get it shut down, but you ain't hurting things. The IR is one of the easiest breathing stoves that I have ever seen. Keep that in mind and shut it down a little earlier. At 500F I slam it down to about 5% open and walk away. Typically it will cruise up to 650-700 and then settle back down to 550-650 for the long haul.
To the person that asked about the ash pan door...don't MAKE me get all monkey boy on ya. DON'T DO IT. (experience speaking).
Shutting down sooner seems to help so far
Thanks. It's nice to be able to ask around with these concerns and see what is normal and what isn't. Burning wood is definately an art, but dang it's fun and addictingThat is not a whole bunch. About the same as mine. I have a little more, but not much (to cure a downdraft issue). I don't think you or the stove is doing anything wrong. As you have noted, turning it down sooner has helped, and I will tell you that the occasional short stint at 750F ain't gonna hurt that stove. You will keep a nice clean pipe to boot.
Burn on - Isle Royale brother. Burn on.
Yep - and you have a darned nice stove to do it with.Thanks. It's nice to be able to ask around with these concerns and see what is normal and what isn't. Burning wood is definately an art, but dang it's fun and addicting
Is your temps more normal now?Thanks. It's nice to be able to ask around with these concerns and see what is normal and what isn't. Burning wood is definately an art, but dang it's fun and addicting
Don't mean to hijack the thread but just curious what kind of burn times you guys get with your Isle Royale? Long slow burn times compared to hot almost over fire times?
I agree, Jags.I hate this question. Please define your burn time. Is 300F still considered active? Or is it 500F? I have gone 24 hrs with enough coals to light up a new load, but it sure wasn't carrying the heat load for the house.
Exactly. Also, if the stove is oversized for your needs, the burn times will be much longer.I hate this question. Please define your burn time. Is 300F still considered active? Or is it 500F? I have gone 24 hrs with enough coals to light up a new load, but it sure wasn't carrying the heat load for the house.
I consider burn times as usable heat for your needs.I agree, Jags.
Seems most refer to having enough coals to relight.
To me. the only sensible, meaningful definition is my stove is still putting out enough heat to heat my house without more than a few degrees fluctuation in the house temp over the burn cycles.
Easier to realize you shut it down too early and open it back up some than it is to shut it down too late and not be able to control a runaway.
