emmelch1 said:I saw one member , I think CWR stated his air is 320 degrees . WOW I thougt I was cooking at 225 degrees . At 225 My stove is getting pretty hot on the surface and the exhaust pipe is really hot. I have the US 6041 (MULTI-FUEL) . I think I would worry if was any hotter, the inside hopper surface facing the front of the stove gets pretty warm tooI know all stoves are different quality and different max heat ratings, but what would be a good guess at My Max. output before the stove would shut itself down ??????? Thanks
tjnamtiw said:CWR said:I have a digital thermometer with a type K thermocouple permanently mounted on top of the stove.. The thermocouple is in the far left hand heat exchanger tube. It's in about 3 inches. Normally it runs around 120 on low, 180 on 2, 250 on 3, 320 on 4, and I haven't run it much on 5. I took some pictures of my temperature monitor and posted them back a year or so ago. When I get a chance, I'll find them and post them.
Chan
Also, if you look at my data, the outer two tubes on my Quads have little or no airflow. I would recommend that you move the probe into the center tubes for a better feel for how hot MOST of your air is. I'd be interested in what you find. My guess is that the temps will be lower because the air is moving faster. I'm not familiar with your stove so I don't know what your settings 1-4 mean.
ChrisWNY said:It's tough for me to measure the air coming directly out of my Fahrenheit furnace because it goes through about 14' or so of 10" to 8" ducting before being blown out into my great room. I'd estimate the air coming out of the 12x20" heat registers is somewhere around 115°F, but I haven't used an IR temp gauge to get a more accurate reading.
j-takeman said:For those of you looking for long term measuring. Check out a data logger.
http://www.lascarelectronics.com/data-logger/index.php
You can track temps for days weeks months. Depending on the sampling increments. I say cool! :coolsmile:
tjnamtiw said:That's some good heatHow many bags a day do you use up there in NY?
If you use an IR gun, be aware of this "Make sure that you are aiming the gun at a surface, be that a floor, wall or whatever you choose, at your target distance. No temperature gun measures ambient air temperature well and you will need to point the gun at a surface so that it can measure the reflected temperature."
http://www.ehow.com/how_7605286_read-gun-ten-feet-away.html
