Yes. The flame is a bit higher. Have to see how it reacts now that the sun is going down but it wasn't doing that with the probe in it's former position.
I was thinking of manual. My stove isn't running today so I can't check it right now. Last night was in the 40'sand today it was 54 out I ran oil .In Room / Manual? Mine does it in Room / Auto . . . . .
Where my probe is presently I've concluded that in this weather my stove comes on too much. The heat came on twice today, once as I got up this morning because I kicked the temp up for the day. And once a couple of hours ago. The stove would have been on off on off in Room Auto and run all day in Room Manual.. So my probe needs to go in the dining room where the house thermostat is. Once moved I can then dial in my controls to match. I think where it is turns out to be a colossal waste of pellets in this time of year when it's mild like this. I just have to try it and see, it tough to compare because the central heat has cast iron radiators in every room that give off heat long after the boiler shuts down. The stove pin point heat with a blower.Testing it now. Temp should hit mid-20's tonight so a good test. Hit 48 today but stayed with the stove as I'm WAY behind last year's consumption.
Harmans don't shut down in room manual unless you run out of pellets.Yes. My stove runs nearly all the time in room/manual.
In the shoulder season I've found pellet consumption to be higher in Room Manual than Room Auto personally and FWIW.
Keep us posted on your board situation. If you don't mind my asking, who is the vendor ?
Thanks, I like that they are freely working with you.Earth Sense Energy Systems
Do you own two boards if it is not found to be defective ?Ok, next step in the saga. The vendor agrees the board is not working correctly in Room Temp / Manual. They will replace the board if it is defective however I had to pay for a new one to be sent out and, when I swap that one out and send back the old one, if it is found to be defective they will refund that price. I guess that's fair enough.
That's how mine works as well. Board is 2011 I believe.I run mine in room/manual nearly all the time. The distribution blower changes speed automatically depending on the need for heat in the room. I keep the temp set at 70-72 and the distribution fan speed set at mid range. My control board is original to the stove manufactured in 2006.
Thing is that, if I don't touch a thing, the room temp drops as well as the fan not functioning.
I have my suspicions on the outcome but will await the result.Feed rate is not the problem, distribution blower function is. Will let you know how the replacement board works out.
