HOW DO YOU PROPERLY INSTALL AN AUGER MOTOR ON A WHITFIELD QUEST PELLET STOVE?!
I have a question about how to install the auger motor properly on this pellet stove. I'm doing something wrong that I can't figure out.
This pellet stove hit the market in 1993, I believe. It came with the Rocky Mountain, Colorado house my wife and I purchased in 2007, as a free-standing basement stove, and up until this winter, I had hardly ever used it--maybe ten times total. But after moving my office to the basement recently, I had been using it quite successfully for the past couple of months until I encountered an auger plug that I had to dislodge by removing the motor and auger screw. Out came the plug. Then, I got busy with other chores and sidelined reassembly for a couple of weeks.
Bad decision, because by that time I had forgotten how both the motor as well as the auger plate had been positioned/oriented with each oher, etc. So anyway, I reinserted the auger screw, attached the auger plate (held by four screws), slid the motor shaft into the bottom end of the auger screw and screwed the set screw into the motor shaft's collar ring and screw, aligning the set screw with the flat side of the shaft. And I had to do all of this in an 8-inch space between the wall and the back of the stove, using mirrors, etc.--not fun.
So...I then turned on the stove and hit the auger button to test it. The auger, as viewed inside the hopper, was turning, but only intermittently. BUT when I looked inside the back of the stove, I could see that the motor itself was rotating in sync with each movement of the auger. In other words, the motor is not held in place by anything, and I don't see how that can be right. Doesn't it have to be held in place somehow? And also...While testing it, I had put a handful of pellets into the hopper to see if it would drop some through the chute. I ran it for about five minutes and it never dropped any pellets even though the auger screw appeared to pulling pellets up.
I'm sure I'm doing something really obviously stupid, but I can't figure out what it is. Does the auger plate, which has a spike that juts out from one corner, have to be positioned correctly to hold the motor in place? Is that the problem?
Any help would be appreciated.
