hareball said:I don't bother putting them on top of the splitting block, I leave them on the ground and start on the outer edges and work my way to the core.
+3
Cluttermagnet said:The big Red Oak that started my whole wood burning hobby was near 4ft at the base. It was way too big to take down safely myself. A pro tree company cut it for me, and they did a great job. They cut the base section of trunk into 8-12in 'cookies'. These were very heavy. It was all I could do to get some of those up on edge and roll 'em. At first, I used wedges and a 'grenade' type as well. Hit 'em with 8 and 10 pound sledges. They eventually split into more manageable quarters. Then I picked 'em off with an 8lb maul. But it was sure a big relief when the neighbor got hold of a loaner 20 ton hydraulic splitter, vertical type. What a big difference that made! It was still making me sore, just to drag all those heavy quarters onto the splitter plate.
I'm still burning that one Oak tree, and I'm well into my 3rd season now (2nd full season). If I were still splitting by hand, I swear I'd still be splitting pieces of that Oak.
There was probably a good 3-4 cords of wood in that one tree, probably 1/3 to 1/2 of the total of what I have burned each year since then. I love Red Oak!
Jags said:Backwoods Savage said:I'd like to see those folks split it with their horizontal method!
Piece of cake Dennis. ;-)
Backwoods Savage said:mtcates said:As for noodling, I've never liked that and think it ridiculous and unnecessary. I've never had a log that it was necessary to do that and never expect to have one. Yes, I now split with hydraulics but I have not always had a hydraulic splitter so have split a lot of firewood over the years.
That's what I thought but was not sure, works pretty good if you have a sharp saw.Backwoods Savage said:Oldspark, that is cutting in the opposite way as you normally do. Sit a block as if you were going to split it and instead of splitting with a wedge or axe, cut down through it with the saw. That way you don't get sawdust, you end up with junk that looks like noodles. I like quad's answer.
Actually, you lay the round down on its side with the bark up and the chain runs with the grain, not across it.Backwoods Savage said:Sit a block as if you were going to split it...
LLigetfa said:Actually, you lay the round down on its side with the bark up and the chain runs with the grain, not across it.Backwoods Savage said:Sit a block as if you were going to split it...
Backwoods Savage said:Not so! If you were Backwoods Savage (not Salvage) you would not have had to lift that thing into your truck at all as you would have already been home. However, if this Backwoods Savage would have been away from home with a truck, he also would have taken a 2 x 10 plank and simply rolled that 20" locust into the truck. If he could not have done it just using his hands, he always has his cant hook with him which makes that task child's play.
I have meant absolutely no offense by my posts about this even though I do sort of jab at a few guys in a playful way but I do most times like to think that people will learn a bit by most of my posts. You see, I have a terrible back my self and have already had 3 surgeries plus terrible scoliosis due to my childhood when I had polio. So I do have to be easy on my back and that is why I try to do things the easy way.....even if it means making my wife do some of the work. ;-)
Backwoods Savage said:Jags said:Backwoods Savage said:I'd like to see those folks split it with their horizontal method!
And a big additional cost! But, dollar bills will do a lot.....
Flatbedford said:I have found that it goes much faster when you go in from the side, than if you go in from the top.
what I like to do is get that sucker up on its side, then hold it steady with my right foot and my left hand, and use the saw with my right hand being all careful to watch out for my left hand's thumb.wendell said:Flatbedford said:I have found that it goes much faster when you go in from the side, than if you go in from the top.
Yes, going from the side is MUCH easier on your saw and it is a lot of fun too!
