How do I replace fuse in Quadrafire Castile
mcbubrooks
2
Central Washington
Hi! I was working on my quadrafire Castile this morning and cleaned the ash out and while pulling the ash holder out it caught the wires and caused them to arc. Fixed the wires but stove won't turn on. Figure it blew the fuse but don't know how to change it out. Any help would be great!
Hi mcb,
The fuse is in the junction box, which connects to the control box, below the red 'call for heat' light. Below is a picture from a different Quad model junction box, but it should look similar to yours. It is held in with a fuse cap that twists and locks the 7 amp glass fuse into the fuse holder.
Make sure you UNPLUG the stove before you pull the fuse out to replace it. Here is a link to the self-help videos put out by Quad that has a Troubleshooting video that shows the Castile fuse location and removal in the first part of the video. http://www.quadrafire.com/Owner-Resources/Use-and-Care-Videos/Castile-Pellet-Stove.aspx
The igniter is a common place for the wires to short out. Hopefully the short-to-ground just took out your fuse and not your control box. Make sure your house circuit breaker for the electrical outlet your stove is plugged into didn't blow also. Post back on how things go after you check the fuse. Regards, DK
Reactions: kappel15
