Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Important question.. In the englander 17-vl manual it says that if I caddy corner it I can keep it 6" from the corner to "unprotected areas".. Where do I take my measurement from?
My wall is constructed in layers like this - natural stone, cement board, metal furring channels, cement board, steel studs (roxul between studs), and wood strips (which are on the other side of the studs of course)
So do I take 6" from the stone or from the wood on the other side of the wall (the combustible)?
Yes you can always lay a pc of metal over the hole temporarily.
Tuck the top under the shingles, enough that the top of the metal is not exposes to any water that may run down between the shingle seams.
Then just screw neoprene washer head screw one on each middle side of the temporary metal pan and a couple at the bottom to secure the temp pan.
The more shingles you can slide under the shingles, including the sides, the less screws you will need temporarily, and less holes that may need to be sealed later.
If you do it so the screw holes fall within the underside of the new roof flashing when it does get installed, the holes are not a problem at all, as they will be covered by the new flashing.
