Effecta Boiler User said:I have an effecta lambda 35 boiler and it has a specially designed "smoke evacuation port" above the door opening that sucks the smoke out the chimney.
This smoke evacuation port practically eliminates the "smoke out the door" problem that is very common on positive pressure gasification boilers such as EKO, Biomass etc.
The effecta lambda 35 boiler has the exhaust fan located on the rear of the boiler and thus sucks the air through the boiler rather than push it through the boiler like the positive pressure boilers which have the fan at the front of the boiler.
The lambda sensor on my effecta lambda 35 boiler works with the motherboard/control panel to automatically/continuously adjust the openings of the primary and secondary draft controls. One can compare the lambda sensor system and stepper motor draft control system on my lambda 35 boiler to an oxygen/acetylene torch. Properly adjusted the flame is very hot and can cut through a 1/2" plate of steel.
Finally, Yes, my effecta boiler can can have an effecta pellet boiler attached to the side of the boiler.
Thanks,
Brian
Thanks,
Brian
mikefrommaine said:Biomass has the rear exhaust fan as well. Smoke out the door seems to be a problem for most newbies (it was for me) but once you learn when and how to open the door the problem goes away.
+1mikefrommaine said:Effecta Boiler User said:I have an effecta lambda 35 boiler and it has a specially designed "smoke evacuation port" above the door opening that sucks the smoke out the chimney.
Thanks,
Brian
henfruit said:How much is the effecta 35?
velvetfoot said:From what I've read, it looks like the Effecta is the least expensive lambda model. Is that true?
I'm thinking 35 would be too much for my house. Maybe I'd need more storage?
Do pellet boilers require storage, or can they follow the load with minimal loss of efficiency? I think there are lambda models for pellet too (Frohling?). Frohling seems quite expensive.
I just noticed that the EKO-25 requires an 8" flue. Is that typical?
 .henfruit said:Could you break that down .
Boiler=
loading valve= What type=
freight=
Thank you
Boiler=
freight=
Thank you
velvetfoot said:Thanks. I got kind of sticker shocked just looking at ss chimney parts, never mind all the rest!
I can see a pellet boiler perhaps, with the potential of same cost for unit, less for venting, and nothing for storage. Operating costs would for me still be somewhat indexed to the price of oil since I currently have to buy my wood whether in. log form or split. Cost of pellets would probably be around cost of split wood.
A guy at work put in a geothermal heat pump. I can see that commodity price being less decoupled from the price of oil, evev here, and the numbers seem way better than oil. Big capital costs though.
Solar would prob. be best, but most liklely not for my place's situation.
I'm in the middle of processing anotherr tri axle load of logs, so I could see that value of being more relaxed about obraining fuel..
velvetfoot said:The Irleh looks interesting. One wonders how easy it'll be to get spare parts in the US in the future with any of these.
(broken link removed)
