I have experimented with veg oil and alcohol for this stove that's in my van. It's got an issue where it backdrafts as soon as you open the door. It doesn't draft well. Some have said because the pipe is not straight, but I didn't want to go through the roof.
Things I've thought of:
![[Hearth.com] How can I get this stove to draft better? [Hearth.com] How can I get this stove to draft better?](https://www.hearth.com/talk/data/attachments/337/337876-fd07ede0c3a0cbccf3ee86a786171185.jpg?hash=hrSZgVmu7o)
That's a pic of the air intake but it didn't help i think cause it's opposite the door but even if i block it it tends to backdraft when i open the door.
I think going straight up through the floor would be better but not sure.
- Putting a 3 inch air intake through the floor of the van up into the stove. Which is a little tricky as I'd like to be able to use it as a vent in the summer too. So trying to figure how to pipe it all up and make it tight and closeable so it doesn't get a bunch of dirt from the rode would be good. I tried putting one on the back of the stove that goes into the drafty drivers area but it didn't work well being opposite the door. If you got any ideas and what to use please share.
- Change the 90 degree pipe to a 45 degree pipe. But it won't fit through the wall nicely as is so it might need a 2nd small 45 right before it goes through the wall because there is a flange in there that fits the existing 90 degree.
- I've heard put an extension on the outlet outside that goes straight up. I made a makeshift one to test that went above the roof and it didn't work well and it's not convenient to be putting it on and off daily.
![[Hearth.com] How can I get this stove to draft better? [Hearth.com] How can I get this stove to draft better?](https://www.hearth.com/talk/data/attachments/337/337874-d41618e4e05c02afd0c54e85b8dca909.jpg?hash=LgT1P3CV8V)
![[Hearth.com] How can I get this stove to draft better? [Hearth.com] How can I get this stove to draft better?](https://www.hearth.com/talk/data/attachments/337/337875-e9d90d8198d6ccf17936e4e60642a485.jpg?hash=QGxOQ0kRSE)
