OK, so I in a way everybody uses their house as heat storage...
Let's say my tank temp is at 160*, it is early evening, I have a nice bed of coals with which I can easily get a gasification going, and I am thinking about loading the boiler with wood. Granted, I am a complete novice, but I think my strategy makes sense... I think I want to fill the boiler with enough wood to satisfy my heating demands for the evening and just barely get the tank to 180*. If I add too much wood, the boiler will idle when the tank gets to 180*, which would be bad. My thermostats are set to 70* and I am too lazy to raise the temperature when I realize I loaded too much wood.
However, I do have a nice ARM based controller a la nofossil, and I also have some nice digital temperature sensors gathering dust. Why not replace my thermostats with my temp sensors, hook them up to the controller, and write a program that basically says that if the house it at 70*, the tank is at 180*, and the boiler is still cranking out hot water, then go ahead and heat the house above the set temp of 70*? The boiler wants to burn, so why not let it? So what if the house gets a little warm, we would be effectively using the house as heat storage.
Does this sound like a good strategy?
