Hi, I apologize if this is redundant. Normally I love to research but I'm quite short on time as of late and would love to hear from the experts. To summarize; I'm a solo mom living in NE Indiana in a 1200 sq ft ranch with a 1200 sq ft finished walkout basement (west facing with patio doors). The home is currently all electric with a heat pump. It's not the warmest or most efficient heat and I fear it may really struggle if we get a harsh winter. Last year (my first winter in the home) I kept the thermostat at 63 degrees (colder when traveling) and my electric bill was still in $3-400's. I am unable to get a propane tank at this point and unsure if that is even the route I'd want to go. I'm leaning heavily towards a wood stove that I could place in the NW corner of the basement with the option of venting it out the exterior wall and run it out & up two stories (on the west side of the home) or a little more than a single story out that north wall (that would require going through concrete). The west side feels like it would be more work since it would be harder to access the west facing wall since the entire basement level is exposed where if it runs out the north side I could lean a ladder against the house and have good access to all the venting. There is no existing chimney in the home hence the wood stove vs insert. I have a few questions and would greatly appreciate any feedback.
-Am I crazy to think I can find a wood stove and get it installed before winter sets in? (edited to add - I will call around the area tomorrow to see if there is any availability. Jan/Feb is an option because I could supplement with space heaters until then.)
-Would you install it on N or W wall? I've attached photos of each if that helps. I can't get them to upload vertically even though they are saved that way. I apologize for that. I drew a circle to give an appropriate location for venting coming out of the home.
-For that square footage is there a stove size/brand you'd recommend? I read that Jotuls have some that aren't as hot which would be a bonus with children. I'd also like a glass door for viewing.
-Will I have to load wood in the night? I go to bed around 10:30/11 and I'm up at 6:30.-Lastly, I have zero experience with wood stoves but I'm a hard worker, quick learn and intelligent. If I go through with this I'll read up on what I need to do to responsibly burn but am I biting off more than I can chew? I already found about a cord of oak I'm going to pick up that's 3-4 years old. I will get more for this winter and then I'm hoping to slowly start splitting my own (I have family that has acreage).
I know more questions will follow but I did want to throw this out there before I put in the work of picking up this wood tomorrow or Wednesday. Thank you in advance for your time.
![West Side.jpg West Side.jpg](https://www.hearth.com/talk/data/attachments/283/283588-b783ae71c52a2c495b2cc95c89653ed8.jpg)
