Honda 5.5hp GX series has no spark
NoPaint
269
USA
I have a Honda 5.5hp GX series engine (red fan shroud with white tank). The engine has no spark. I cleaned off the flywheel and still no spark. I am willing to throw some parts at it to fix it. Should I just replace the coil or condenser/both?
Check the ground on the coil, I have found a loose coil bolt/screw to cause no spark.
Check coil with a ohm meter, should have a few ohms, almost a short thru the coil.
Rare to have a coil go bad but possible. Cracked & got wet, look burned?
Check the plug wire,
Good spark plug? cracks, gap to big etc.
Does it have an On/Off switch? make sure it's working & not shorted to ground when in the "ON"/ "run" position.
If your sure it's bad, remove the plug, switch to the "run" position, put a screw driver in the plug wire cap, hold to the metal part of the screw driver in your hand, with your knee touching the engine, & give it a hard pull.
Still able to speak something other than cuss words, something is definitely wrong. ;)
Typically not very expensive to get repaired, small engine repair shop near you, probably have parts
Bondo said:
Ayuh,... Disconnect the low oil shut-down switch,... They're known to go Bad...
It'll look like a Nut on the crankcase, with 2 wires coming out of it, just unplug either of the wires,+ Try it...
And check your oil to see if it is low too or you will be asking us about low compresson next....LOL
Haha yeah i grounded out the hose pressure switch on the pressure washer pump. I think the switch is fine simply because its so basic. I didn't know the oil switches go bad. I will ground that and see how it goes.
