homemade copper coils
NHFarmer
294
southeastern NH
I have been working on my Tarm install for about a month or so and I must admit this project is costing a small fortune.I decided to go with a 1000 Gallon storage tank and copper coil HX.I bought 300' of 1/2" type L copper in 20'sticks.I am bending them into 20" diam.coils,4 in total,1"manifold between them .The bending is going ok but they sure look ugly.What I am trying to figure out is how to support them,they want to fall over and the 1/2" pipe isn't doing a good job of holding the mess together.Also some coils are touching each other,will vibration be a problem?I am now thinking maybe a pvc cage to hold it all together?Anyone have any Ideas??
Have a look at Kevins set up, he did a right smart job.
(broken link removed to http://picasaweb.google.com/pittman.jim/KevinSBoilerWorks?authkey=apvdOuoreyAdMc9MtlxgAJy5Yk8)
NOTE: I fixed the link it.
I just made my first coil based on his design, 3 50' coils of 3/4" refrigeration tubing, wound 22" dia. 43" tall. I supported them using 1/2 pvc pipe with holes drilled every 1 5/8" and a bunch of zip ties.
A couple of unions, 2 adapters 5/8" to 3/4" (refrigeration tubing is smaller than plumbing pipe), 2 90's and some straight 3/4 pipe and I had a very nice heat exchanger. It even held 60 psi over night! Now to make the other 3.
Greg H
Tarm excell 2000
1200 gallons storage
6 solar panels
Hi NHFarmer,
I've been installing my Solo40 and am almost near the end too. I can agree with you on the cost and time it took to install, I also replaced my manifold.
I purchased the tank from STSS. The coils that they ship have 3 pieces of copper tubing running perpendicular to the coils. About every 4'th coil is soldered or braised to the 3 vertical tubes. They attach 1 tube to the end of the coil for the return.
(broken link removed to http://woodnotoil.googlepages.com/constructionlog) (about halfway down)
I wove copper wire that I ripped out of some old electrical wiring up two sides to help support it. A CPVC frame can also help or soldering to vertical copper if you have scrap around. I didn't want to buy extra copper just for that purpose.
Thanks for all the input,I like the cpvc idea.Still experimenting
I just realized the link I posted above didn't work. I couldn't check it from work, big brother won't let me go to photo archive sites.
I've fixed it so you can go to Kevins page. Here it is again.
Greg H
Greg
Thanks for the link.I only wish my coils looked half as good as his do.Looks like he has put a lot of time into his system.
It really wasn't that hard. The one mistake I made was soldering the next 50 ft coil together as I finished the first one so at the end I was chasing 150' of tubing around and the loops kept growing on me. I was able to even things out later as I tied the coils to my pvc pipe. For the next one I'll try making 3 seperate 50'coils then joining them.
I have to stop being anal about keeping the coils +-.050 in. They're going into a tank of water for crying out out loud.
But seeing Kevins set up saved me hours of experimenting.
Greg H
goog god man, you 'bent' coppper to make coils?
softroll copper in 50-100' rolls (coiled, don't you know)
Yea but look at the money I saved!!!!!!!!!!!!! If I could do it again I think I would look at other options Too much work and not a lot of fun
