I have appreciated all the input and will be installing baseboards. I was not clear when I mentioned the resistance heating, what I was thinking of was the heating that is a byproduct of any electrical consumption. If you purchase 55 kwh per month my guess is that 80% of that turns into heat inside your home ( less if you are forced to buy the idiotic florescent lights).
Here in B.C they are trying to do away with the incandescent bulbs which provide light and heat.
We have been in this place two years and the former owner had cobbled together a wood/oil fired hot water system that pumped to the house into radiators.
Good idea had it been done properly and they must have spent a lot of money on all the copper piping alone ( lots of 1 1/2 inch pipe and valves). We have removed some rads already and just use the stoves, so much simpler and no electricity needed.
DougA, you mentioned tornadoes, I was in the Barrie area when a nasty twister went through. I had never seen a sky that color of very angry green before, 1985 I think.
