Yes but repeated incidents like this will destroy the stove. I have seen it before. We just replace a 3 year old 3100 that the top was warped so bad the top was down 3/4" at the stove collar and the front was bad enough you couldn't close the door. They guy said oh yeah I had it glowing all the time
I would think they'd have a fixture or jig to hold the two sections in place for welding, but who knows?the weld itself is not a straight line so it actually appears it was manufactured that way. On this stove, the front and sides are the same piece of metal bent into a U shape, so my guess is the bending process can leave the front non-planar.
Not all that much since you can compensate where the gasket sits with more or less glue under it.It's only about 1/8" off of being flat, but that means the door gasket is filling a 1/4" gap at the ends and about 3/8" in the middle. Wonder how much it's going to bug me now that I'm aware of it![]()
the learning curve for proper use may be a little steeper for less experienced people, and when used carelessly the stakes are a little higher.
No arguments there jetsam. I was thinking more about shortening the life-span of the cat element by clogging it up etc. and not the ultimately high stake issues of burning your house down. With my Napoleon the most common outcomes from overfiring (within reason) are shortening the life span of the airwash baffle or the secondary baffle. Both of those parts can be replaced for less than $30. If you clog a cat element by burning wet wood or other incorrect use the replacement costs are significantly higher.I hate to take the bait here, but you got both of those things backwards.
The safest stoves available all have cats in 'em. You have to either leave the door open or have a hardware failure to overfire a BK. They're also simpler to operate than even old pre-EPA stoves, let alone something with two air controls (mainly because you can't overfire it-on a hot reload you put the wood in, close the door, close the bypass, walk away.).
I have a wife who isn't that interested in learning about stoves, so I would probably be risking a melted stove if I had any sort of tube stove or pre-EPA stove.
Point well taken and I don't question or argue with your experience at all. I've just read quite a few posts of troubled beginners who have struggled to keep their cat elements in proper working order, presumably due to careless or uninformed use, and then been told by dealers or manufacturers that they need to replace the cat even though its only been in use a couple of years or so.I have been burning wet wood in my stove since I got it. I would need to remove the flame guard and pack mud up there with an ice cream scoop to clog the cat. If I did do this improbable thing, I could unclog it by rinsing it in the sink.
The cat is a $200 grid of ceramic or steel, not a $2000 box of delicate electronics.
