Funny, when I said this the other day I had a response saying " how can you over load/over fire your stove?" eluding that I was an idiot.
I hit just over 1300 my 3rd fire, with ash and pallet wood, dumb rookie mistake. I was terrified. Shut the air down, dumped flour in the firebox (I had nothing in the ash bucket yet) and ran out of my house to check the chimney as I screamed past my husband what was going on. Because the stove and chimney was so new, and we had painted shrouds throughout the house with the double wall inside, it STUNK in my house for hours. I sat with a flash light watching the flue probe go down, looking for anything glowing (never happened) i didn't light the stove again until my installers came out to inspect everything, they got a chuckle out of the flour in the firebox but all ended up being ok. Now I hit 1,000 every now and then but I don't reach for the flour, I just damper down and wait it out, a few minutes it calms down and so do I.
Here is your push, your stovetop temp is good to know if your cooking on it, knowing what flying through your chimney gives you a whole other layer of perspective and comfort. DO IT and post a photo or I will continue to pester you until you do![]()
For the record . . . putting floor on a fire is generally not a good idea . . . if applied incorrectly it can not only catch on fire, but can actually explode . . . if just dumped on to a fire it will typically put out a fire simply by cutting it off from the oxygen supply . . . but a far better material to use would have been baking soda. Just a FYI.
Incidentally . . . these flour dust explosions most often occur in mills and not homes though . . .
http://lacrossetribune.com/newsupda...cle_f0c46c39-58c5-5025-8ef9-b16f35e3dc0d.html
I think you guys are worring about nothing, a spike once in a while at those temps is nothing to worry about.
600 aint nothing, hit that several times a week with no smell or smoking, if new install did they leave a sticker some where?i hit 600 on the single wall the other day. support box was smoking.. i shut the air down and closed the damper an you could instantly hear the metal shrinking.. sounded like someone throwing handfuls of BB's in there... Its still under investigation. some other members suggested the installer may have left some debris in there. either way i need it checked. also want to look into a probe...
Hey rideau, post a picture. I want to see the grey Woodstock and stove pipeI did it. I installed the probe thermometer...another toy to play with.
So far, the probe is pretty consistently three times the exterior magnetic thermometer.
I have ICC ultrablack.
I paint my pipe grey to match my Woodstock stove, every time I take it apart, if and where it gets scratched. No big deal when I first use the stove after. A slight smell, but no smoke or anything of concern.
Left my camera at the other house. Will try to find a shot in my photo archive. If I do, I'll post it.Hey rideau, post a picture. I want to see the grey Woodstock and stove pipe
