Lake Girl,
Yes, The wood and steel bracket to the left of the stove is weight bearing big time. There are two 50" apart O.C. (on center). The other is to the left of the one you see in the pics. One picks up bearing in that wall line and the other picks up bearing in a 90* or perpendicular wall and roof line. I welded two large C - channels together there forming a 8" x 8" square box beams at both locations which carries the second floor and roof loads. Did it out of steel because they span 24' and 32' ft. and I could not find timbers big enough and long enough. Being straight and reasonably priced was out of the question also. The 90* beam is 32' ft. long. They also sit on an 8" square wood timber posts right behind what you see. I come up with the insane ideas and a friend (a structural engineer stamps the stuff) but he will not unless it meets or exceeds requirements. Unless, I feed him lots of beers of course.....
It is all open to below and these lines used to be an exterior bearing walls that I took out. I more or less restructured the existing home and built another around it. Above the stove it goes up two stories all open with a vaulted ceiling. Real fun changing bulbs and cleaning the ceiling fans up there. NOT! I also had to drive the point home with my better half that she can pick the colors, whatever she wants, but she had better get it right the first time because I was only going to paint it once. She did well. I have a feeling I will be doing it again before the holidays. It's about due and I am still finishing things anyway. She has sprung a color chance...... Yet. Our other home sold quicker than planned and we had to shot gun into here 5 years ago. I bought the property almost 13 years ago and originally was a man cave with room to roam inside and out. This project went from no pressure to get it done yesterday. Then I get busy and it gets put on hold again. Vicious cycle! I am taking some time off to get it done though.
