Help with St. Croix Pellet Stove?
Hello again OK i made some adjustments and straighten the OAK and open the damper the size of a pencil.. Now my question is the flame seems good running it for 15 hours on setting 3 and look at the vid below and tell me does this look normal and OK to you?
http://www.youtube.com/watch?v=kDhTUkggZUI
What do you think?
That is looking pretty good.
BTW, I sent you a PM you might want to check into that as well.
krooser said:
Only open the damper the diameter of a pencil...if you need more air the stove is dirty...
Most of the time yes, but that is not always the case.
well i installed a thermostat today but i have to look into it more i set it to smartstat and i think i might have to the unit off and reset it i try to switch it over leaving it on but for some reason i was getting black soot again
Did you read my PM?
I think that what you did looks good.
I also don't want you to forget the actual exhaust venting either so I sent you a PM as a reminder.
