I could use some help with sizing of a pump and plate heat exchanger for my new E-classic. Here is a basic over view of the installation. I have an older farm house in the country with baseboard hot water heat. The current propane boiler is rated at 200,000 BTU input with approx 150,000 BTU output to the water system. My plan is to keep the current propane boiler system intact and use a plate heat exchanger. I am also planning on installing a side arm on the hot water heater. My E-classic will be approx 110 ft from the house and down a hill about 15ft. I am planning on using 1" Thermopex for the run between the E-classic and the house. My questions are as follows. How large of a heat exchanger do I need and what pump would be required for this long of a uphill run? The final install will also have the E-classic heating my shop of 40X70 via infloor heat, but for the time being need to get the house nice and warm. Thanks in advance.
! large heat load+ distance 1" will not transfer the BTU. Spend a little extra now and run a smaller pump will save you$$$ and problems in the future.
