Help with double wall on blaze king
BobFalfa
31
Missouri
So after a few years of only having a single wall section of flu pipe coming off the blaze king to my class a chimney i decided to change it out for a piece of double wall. So i have the new sections of double wall but now i am unsure of how to connect it to my ceiling connector. The new flu pipe is too big to right. I have posted a couple pictures. That show the new pipe and where it needs to be connected. Thanks
  • Help with double wall on blaze king
Here is another picture, showing the old piece that is stuck in the new double, iam pretty sure this isnt the way it is supposed to be either
Are the Chimney system components by Security?
The stovepipe should be 6" ID. What is the OD of the ceiling support stub?
That is a little odd. The catalog shows 8" ID for that pipe.
Same ID on both ends?
That is a double-wall adjustable length. I've never used it, but according to the literature it is designed to slip over regular stove pipe.
Providing you have matched up the correct diameters, the ID on Security's double-wall pipe should be just slightly larger than the flue adapter poking down. At the top of the flue adapter, you will notice a raised bead. When you push the pipe overtop of the extension, this bead should seal everything up. Drive three 3/4" self-tapping screws (instructions may say two) through to fasten pipe to extension.
Need more info, call Security's Tech Support line at 800-361-4909.
