Jack Straw said:
b121 said:
With a Lopi Endeavor I tried heating a finished basement (1500 sf) with open stairs and my main floor (1500 sf)
thinking the heat would rise up the open stairs to the main floor.
All I got was 90 + degrees in the basement an 65 degrees on the main floor.
With a lite candle I could detect cold air returning to the basement along the nosing of the stair steps and warm air
flowing up stairs along the ceiling of the basement to the open stairs. So there was an exchange of hot/cold air taking place
but not at the volume required to comfortably heat both floor levels. Floor grates may have helped improve this hot/cold air exchange, but from what I've read
about a wood stove in the basement, it's still difficult getting the proper hot/cold air exchange.
We don't use the finished basement very much so for next winter I just recently installed a Woodsock Fireview at my main level and the basement will be heated with oil (hot water baseboard) with the thermostat turned back to 60 degrees.
I think you had too small of a stove for you area. I am Heating 1500 sf in total with an endeavor.
I am glad the Endeavor works well for you and I agree the Endeavor is rated for 1,200 to 2000 sf not 3000 sf.
I like the looks of the Endeavor and I loved watching the fire display.
Originally I had the Endeavor upstairs with the intent to heat just the upstairs (1500sf)
I was not happy with trying to maintain proper stove pipe temp , as to not promote creosote, and temp to keep the secondary burn going, plus
trying to maintain a comfortable living area temp (70s). To do this, I limited the size of the fire with smaller loads of wood, but had to feed the stove more often.
I thought a better solution would be to make the Endeavor heat more square footage by placing it in the basement.
I could put large loads of wood in it and be able to maintain proper stove pipe temp for longer periods of time between adding wood.
The extra heat produced would just flow upstairs, but that resulted in the above mentioned scenario.
I hope the Woodstock Fireview will work better for me, but it does not have as good a fire display as the Endeavor (I'll miss that)
With just a few test fires I found I don't have to run the Fireview as hot, because of the catalytic converter, and I like even temp from the soapstone.
However the real test will come this next heating season.
