hi i have a new drolet heat max 4 months old, blower wont stay on long , im burning a lot of wood . it seem hard to heat my house that is only 1000sq feet, could it be the thermo disc gone.
they said it could be static presure so i put dampers in the 2 8 inchWhat did PSG say when you called them ?
Can you provide some pictures of your install ?
Wh
What are your high and low temps set to on the snapdisc ? Mine are set to 100F off and 150F on.
hi i have a reaAre your secondaries lightning off once you get a good fire going ?
Did you change the settings on the snap disc or is that how it was serom factory ? 160 and 120 seem too high IMHO.
Mine was set at 150 on and 100 off from the factory.
EDIT: Pictures speak a thousand words also.![]()
hi iAre your secondaries lightning off once you get a good fire going ?
Did you change the settings on the snap disc or is that how it was set from factory ? 160 and 120 seem too high IMHO.
Hi I have really good secondary lighting,I never change the snap disc I will get some picturesAre your secondaries lightning off once you get a good fire going ?
Pictures the first one is drafter closed other openhi i have a rea
hi i
furnace blower wont come on right away and when it do only for 5-10 min
@laynes69 helped me get my damper dialed in. When my thermostat is calling for heat the damper is only open about and 1/8". I just put a nail in the damper when I am starting a fire to give it some extra air. To me it looks like your damper is too far open. I am not sure if that can be adjustable on that furnace.Pictures the first one is drafter closed other open
the furnace room is not cold in there.hi i tryed closeing the drafter that is not open all the way blower still wont stay going long. i tryed running it manuelly , i never check the draft from my chimney i know it drawing good, no i dont have a barometric . i have some air from the furnace room being pull in and i have a cold intake running to my main floor.
i can not change the setting on the snap disc on less i put other one in, the company is sending me one to cut in at 110 instaed of 120Are your secondaries lightning off once you get a good fire going ?
Maybe you have addressed this elsewhere already but this sounds kinda like wood that is not dry enough. From what I have read, these things like really dry wood. It can make a huge difference in heat output.hi i tryed closeing the drafter that is not open all the way blower still wont stay going long
I haven't actually laid my hands on it yet, but from the looks of things from the parts diagram, it is adjustable. It shows a rotary damper control with 12 holes all around the wheel and the damper push rod is in the 10 or 11 o'clock(ish) position.I don't know if the damper is adjustable on the Tundra.
im going to rent one i think, i have a prefabWhat do you have for a chimney? If you say its drawing good, and have no baro, you might have too much draft too. Order that manometer yet?![]()
yeah i did do that already adjusted the damper , the blower will stay going if the damper is open all the was.I haven't actually laid my hands on it yet, but from the looks of things from the parts diagram, it is adjustable. It shows a rotary damper control with 12 holes all around the wheel and the damper push rod is in the 10 or 11 o'clock(ish) position.
i have a baro i purchead it 2 days agoWhat do you have for a chimney? If you say its drawing good, and have no baro, you might have too much draft too. Order that manometer yet?![]()
Try putting a filter on it. That will lower the CFM output of the blower a bit. Lowering the output of the blower air lowers the cooling effect of the air on the furnaces heat exchangers, and that will keep the blower on longer and raise the air temp coming out of the registers too. Don't hafta buy the filter kit but try it even if you have to just duct tape something on there temporary for testing. The higher the MERV rating of the filter provides for more restriction. Don't go too crazy with it though, that blower still has to be able to keep the furnace cool if things get a lil hot sometimes!i dont have a fillter on it
I will try that thanks I will try anything nowTry putting a filter on it. That will lower the CFM of the blower a bit. Lowering the velocity of the blower air lowers the cooling effect of the air on the furnaces heat exchangers. That will keep the blower on longer and raise the air temp coming out of the registers too. Don't hafta buy the filter kit but try it even if you have to just duct tape something on there temporary for testing. The higher the MERV rating of the filter provides for more restriction. Don't go too crazy with it though, that blower still has to be able to keep the furnace cool if things get a lil hot sometimes!
Oh, and you will have to cover the other blower intake grill(s) with some tin (or maybe some cardboard, just for temporary testing purposes)I will try that thanks I will try anything now
