I am renting a house w/ an old wood stove that can load from the front or the side. I think it's a Heartstone (see front and side pictures). When we have used the stove, burning hardwoods, the wood burns up super fast. We can't possibly keep a slow burn and we've never had embers left in the morning. The stove is cold by then. I have questions about how it is supposed to operate and about an assessment I paid for with a wood stove repairman.
1. I can't figure out where the primary air intake comes from. There is a pipe vent at the rear bottom of the stove (pictured) that opens and shuts with a wire and a lever up to the back of the stove. That pipe and lever seem to be for cleaning out the ash pan area after the ash pan has been removed. It doesn't appear to provide air to the stove. Rather, it dead ends into the ash pan chamber. This stove has the ash pan opening on the side entry side.
2. Their is an internal air control pipe that is bent and cracked. The pipe (see pictures) leads to a 1" (+/-) hole in the sidewall of the stove on the side opposite the loading side. The opening is covered with a swinging cast iron "stop" but because the pipe is bent, it pulled inward and the stopper thingie doesn't meet the end of the pipe. It is about 1/4" too far away from where the pipe should be exiting the stove (?) so air gets in all around the hole. The stove guy told me that excessive heat and age would have been responsible for bending and cracking the pipe and it would need to be replaced. I looked at tons of photos of stoves online and didn't see one stove that had this little hole and stop thing on the side to meet up with the air control pipe.
3. There are cracks in the soapstone panels - one on each side and one on the rear of the stove. Stove guy said these are probably from excessive heat. He wasn't sure if they needed to be caulked or replaced for safety's sake.
I crawled behind the stove and on the lower left rear ia an number incised into the soapstone. As best I can tell it reads "81-11139-7PB. Nothing like that number turned up on a google search. I think the stove could be 25 years old or perhaps older.
My rental lease reads that the wood stove is to be in good working order and that the landlord will maintain it as such. I don't think it's in good working order. And I want to be able to use it safely and with reasonable wood burn. Any help / thoughts?
