Okay so I have narrowed down my only option for a wood stove insert is the Osborn 1800. It will be tight but it does fit and there is only one other issue that I am facing. After talking with a retailer up in Kent, WA he said I could remove part of the facing skirt to "push" the stove 1.5" farther into my ZC fireplace. I have made some accurate measurements and so the fluespacings pdf below shows that I will have a 0.46 inch misalignment between my existing chimney and the new 6" diameter chimney that I will be installing. There will be about 2" of clearence between the top of the stove and the top surface of my ZC fireplace.
http://ray.mccormack.home.comcast.net/woodinsert/fluespacings10282006.pdf
http://ray.mccormack.home.comcast.net/woodinsert/housefireplacedimensions10282006.pdf
Do you think this will be a feasible installation for me???
Any help greatly appreciated.
