The airflow switch on my stove isnt getting 5 volt and the #2 light is flashing, i checked all the wiring for loose connection ang all are ok, My stove retailer said that i need a new board, is this control board fixable?
There are several companies out there that can repair the control boards used on the Big E. Just search for pellet control board rebuild or pellet control board repair and you can find them.
My guess is that the control board is fine but the wiring harness is bad. try pushing the pins up into the molex. I think it's a gray wire on your stove. All of the wires in the right location? Sometimes the disconnects can have a bad crimp too.
