I have been using an OWB for the last 5 years. Over the last heating season, the unit developed a slow leak and after further inspection needs to be replaced. This leaves me with the choice of either replacing it with another OWB (I’ll probably go with Central as at least they are likely to be in business in 5 years) or going with a gasifier. I have been pouring over this site over the last couple of weeks and have learned quite a bit thanks to those who have shared their knowledge and experiences. However, I need to ask a few more questions to guide my decision.
Background: My house is ~1500 sq. ft. in south central Wisconsin and I heat entirely with wood (I run my LP furnace once a year just to make sure it still works) and use LP for DHW in the summer months. The house is moderately well insulated (2x4 stud walls with R13 fiberglass and 1” additional polystyrene outside, decent double pane windows, etc). Before the OWB I would use 800 – 1000 gallons of LP per year. I currently use ~ 12 full cords per winter in the OWB, 99% of the wood is standing dead elm. I own ~36 wooded acres with a considerable amount of dead and dying elm left for use as fuel. I am currently considering and EKO 40 with some type of storage. My current plans are to use 500 gallons of pressurized storage, but this is contingent on finding an LP tank that won't be outside of my budget. The EKO and the storage will be in an insulated building ~ 30 feet from the house (the current site of my OWB). I don’t have room or a good way (no walk out basement) to put the storage in the basement. I will keep the DHW plate HX, forced air HX and underground PEX that was used with the OWB. I plan on running the water temperature between 140 and 180 F as this worked well with the forced air system that I have been using.
Questions:
1: For those that own a gasifier, how difficult was it to get the stove set up initially and how much fussing did it need throughout the winter? I don’t have any problem with some work tuning the setup, but occasionally I get sent out of town for work with short notice. I don’t want to have a situation where my wife will have trouble keeping the system going. In the past years, filling the OWB has not been a problem for her, I just don’t want to get into a system that will require a lot of continual tweaking.
2: How much maintenance is required on a gasifier? Parts that are known problems or need replacement after a few years of operation?
3: Understanding that you folks on this board have not seen my house and understanding the conditions in the “Which wood stove is right for me” disclaimer above, I still have to ask if there is anyone out there with a similar setup (house size, climate, etc) who can verify the EKO 40 is approximately the right size. I would like to be able to fire the boiler once per day in all but the coldest few weeks of the year. At a minimum I need the system to hold out for at least 8 hours overnight with temperatures of –15 F. I don’t plan on using answers as substitute for good judgment, but it’s always nice to have a little more data to work with.
4: How do you gasifier users operate your boiler with respect to loading wood, etc? It seems to me the boiler would be run to bring the storage temperature up and after the boiler shuts off additional wood could be added to fill the fire box if necessary to increase the system capability for the coldest periods. I assume there will be some loss of efficiency to have the boiler idle with a fire box full of wood, but does this type of operation cause other problems?
5: For those that have made the switch from OWB to gasifier, what was your approximate change in wood used?
6: If anyone has a source for LP tanks in the southern WI, northern IL region, please let me know.
Sorry to create such a long post, but I figure its better to provide as much information as possible. If there are any additional details please let me know. Thanks in advance for your help.
Eric
Questions:
Eric
Once installed the boiler is mostly maintenance free. A lot depends on using seasoned wood...keeps everything cleaner. I don't travel, but my wife checks on and stokes the boiler at least once most days in cold weather.
