Contact your local community for help. There may be someone they can refer you to to help fix the oil leak
Mark Fellows said:Fatmikey197 said:my dad bought a used pellet stove off craigslist. when he started it the first time it was ok ,but the second night he had it on it burned out of control. the auger never stopped going. it kept feeding the pellets in at high speed. the fire burned out of control and got larger and larger till the fire got into the hopper and burned all the pellets in there till the fire was climbing out of the pipe on the outside of the house.
it is a derco grizzly, ultimate achiever. the company is out of buisness and noone can fInd an owners manual.
WHEN IT REACHES OPERATING TEMP IT IS SUPPOSED TO START TO MANUALLY FEED THE PELLETS BUT IT DOESNT STOP.
THE BLOWER STAYS ON AND THE LIGHTS DONT WORK.
PLEASE HELP US THEY ARE GETTING UP THERE IN AGE AND HAVE NO OTHER WAY TO HEAT THERE HOUSE DUE TO A LEAK IN THE OIL TANK.
The following is intended to be discussion only, and is not professional advice. I urge you to seek professional help on this problem.
Don't run the pellet stove again, until this is figured out.
Option 1
For the short term, you can get a Kerosene heater from Lowes and a Carbon Monoxide detector. They only stink when they first start up and after shut down. There is a fuel Home Depot sells around these parts called "Clean Heat" or something like that. It is manufactured by the same company that also sells K1 Kerosene in 5 gallon cans in HD and lowes. I used to burn it. It says specifically sold for Kerosene stoves, and it stinks less. A large sized Kerosene heater will heat a smaller house just fine. They are however dangerous if not used properly. You must fill them outside and carry them inside. You must adjust the flame properly and not try to "turn it down on low" or you will produce Carbon Monoxid, and in short read all of the directions.
If you have a fire in your house while one of these is burning, my understanding is that the insurance company won't pay the policy.
Option 2
for a long term solution, fix the oil tank. There might be products to patch the leak. I found one.
http://www.pplmotorhomes.com/parts/caulks-sealants/40754.htm
Option 3
This can be done simultaneiously while you are working on getting heat in the house. Have a shop that sells pellet stoves come out and look at it.
Possible Option 4
Have a company that services furnaces come out and look at it.
Possible Option 5
Have a real electronics technician come out and trouble shoot it. Not just someone who claims to be an Electronics Tecnician. There are a lot of them. Just like there are a lot of people who claim to be mechanics.
Good luck! That is a scary situation!
I would patch a oil tank so it could be run dry, I would never add oil to a patched tank. Oil smell from a leak is too bad to risk.
slls said:Mark Fellows said:Fatmikey197 said:my dad bought a used pellet stove off craigslist. when he started it the first time it was ok ,but the second night he had it on it burned out of control. the auger never stopped going. it kept feeding the pellets in at high speed. the fire burned out of control and got larger and larger till the fire got into the hopper and burned all the pellets in there till the fire was climbing out of the pipe on the outside of the house.
Option 1
Option 2
Option 3
Possible Option 4
Possible Option 5
we did he says i bought a used stove and its now my problem I am thinking of brining him to court,RingOfFire said:Contact the former owner if you can??????????
