![Help me get my DHW working Help me get my DHW working](https://www.hearth.com/talk/data/attachments/188/188474-06a29e52fd77cc721faeb650abe8008d.jpg)
![Help me get my DHW working Help me get my DHW working](https://www.hearth.com/talk/data/attachments/188/188475-1b8e95983dd4564b9ff753136a2b70a2.jpg)
![Help me get my DHW working Help me get my DHW working](https://www.hearth.com/talk/data/attachments/188/188476-2a8505cb38650c74a32b124c3d68b71f.jpg)
If you're getting some replumbing done anyway, I might also ask the guy (if he's any good at the hydronic stuff) about getting rid of all those circulators in favor of a single variable speed one (Alpha). We can't see what else is going on there & it might be pointless - but shouldn't hurt to ask. Would likely require adding zone valves.
I dont like seeing zones plumbed that way. You usually end up with ghost flow issues. As mentioned above could easily be converted ans save on electricity. The zone valve would also eliminate Ghost flow. I have plumbed side arms in a few different ways. One way is a circ on both sides ran off a sensor. Could use lower T stat on WH if always going to be heating DHW with wood. I hook up a lot of OWB that need the water always moving through them to not get hot/cold spots, on those we plumb the primary loop from the Boiler in through the sidearm and let the water from the WH thermosyphon through the side are with a mixing valve on the domestic side. Quite a few other ways..... I do not like to use a circ on the WH side just more electicity used, however if you have storage and a primary loop that isnt always moving water this wont work. If you do go with a circ on both sides I do not like to use a side arm, Not as much heat transfer area as a plate exchanger.
I'm curious, what's the boiler setup? Wood? Storage? If gas, why bother since the water heater is gas?
edit: stupid observation, but it looks like that pump is valved off.
