We have a large home, constructed 3 stories with ICF. Our basement is 3000 sq. ft.(9' ceilings), main is 3000 (9-15' ceiling)and up is another 1400(9' Ceilings). The basement is just framed and fitted with 6" triple wall through the side of the home @ 6' and the flue is about 25'
I have read many posts here and am still wondering which of these large stoves will be right. I know it won't heat the whole home, but want it to supplement the furnace and have the ability to heat if we loose power. There is a large intake for the furnace in the hall just outside the basement landing and I think I can use the furnace blower to help distribute the heat when wanted. The Alderlea is the highest rated BTU 97,000 with the Lennox coming in right behind at 84,500, the Jotul 81,500 and the Quad 70,300. I just don't know how much weight to put on those ratings. All have blowers around 125 CFM with the exception of the Lennox with 700CFM. I also don't know what is best for our situation as far as the way each stove actually works, radiant etc. We will be burning quakie, cedar and a little oak. I have not had a wood stove since I was a kid and that was QUITE a few years ago! I got a GREAT quote on a Defiant, but not sure that is going to be a hot enough stove for us. So if anyone has any words of wisdom for me to draw upon - I would appreciate the input. I probably needed a big Blaze King or Hearthstone Exuinox but am stuck with the 6" pipe.
Thanks, Carol
Thanks, Carol
