Parkville MD. Anyone on here nearby? I need HELP. Pinched my chain AND Bar in the oak log I previously posted about. I will fill up your pickup truck with chunks of oak for helping!!
It doesn’t have to be today or tomorrow. Whenever I’m the next few weeks!!Parkville MD. Anyone on here nearby? I need HELP. Pinched my chain AND Bar in the oak log I previously posted about. I will fill up your pickup truck with chunks of oak for helping!!
I've only got one saw. That's what I tell my wife at least.A man with one saw is one saw short.
Not yet. I’m going tomorrow and will pound a wedge in, as suggested. I may buy an extra bar and chain too, will see how the wedge does. The head of the saw is with me. It’s the bar and chain that I need to free up. Will bring a Jack too.Any luck getting your saw back?
Pretty sure you are not jacking that monster up much at all. Jack will just sink into the ground.Not yet. I’m going tomorrow and will pound a wedge in, as suggested. I may buy an extra bar and chain too, will see how the wedge does. The head of the saw is with me. It’s the bar and chain that I need to free up. Will bring a Jack too.
I've lost the battle to convince myself that I can find a lightly-used top-handle saw and save some money. Heading to the saw shop now.. 😏Might be a good time to buy another saw, I've seen a lot of good deals on used one time for a job saws. Many people will buy a saw to cut the tree in the yard and then sell it after they scare themselves or realize they don't like work.
Right. I would pound several half-round splits, flat side down, under the trunk with a sledge hammer or maul, flat side down, starting at the edge of the shed and working right. Then start taking rounds off the left end. When you get to the first half-round support, rinse and repeat.Obviously you've learned a lesson about where to start your cuts.
Thank youFor those like me who were struggling to understand the situation, I went to the other thread and found a photo of what the OP is working on. He said that he tried to cut it at the fence.
Obviously you've learned a lesson about where to start your cuts. Personally I would have started in front of that white shed with a small top cut no deeper than the bar. Then switch to a bottom cut because the tree is elevated there and will want to drop to the ground. It will collapse on top where you put your first slice, and leave your bar in the clear as the chain cuts upward.
If you get a new bar and chain, then cut it about where I indicated below. That will release the stress and un-pinch your bar because the end where you make this cut will drop down. As someone said, you could try jacking it but you need a very strong jack and need to put something on the ground to spread out the weight, such as 2x4s or better yet a thick steel plate. I don't think that a wedge is going to be able to move the tree back to the position it was in before it pinched your bar. It could have prevented it from shifting to that position, but moving it back is a lot to ask.
Good luck!
Not yet. I ordered an 18inch bar and chain( I wanted an upgrade to the stock 16” anyway) for $65. When it gets here I’ll put it on the saw, first I’ll try putting my wedge in the kerf. After that, with clear escape route, I will cut a little from the top, and then do the final cut from the bottom. I’ll take pictures of everything and post them. Lots of help on here, thank you all !!Did you get your saw out? A hydraulic jack and a couple of pieces of wood will take the pressure off.
Go to Harbor Freight and get a Hydraulic bottle jack. Use a couple of pieces of scrap wood or a cement block and take the pressure off and get your saw out. I'd rather unpinch my saw then cut it and crush my saw. Escape route shouldn't be a problem unless you're laying under it.Not yet. I ordered an 18inch bar and chain( I wanted an upgrade to the stock 16” anyway) for $65. When it gets here I’ll put it on the saw, first I’ll try putting my wedge in the kerf. After that, with clear escape route, I will cut a little from the top, and then do the final cut from the bottom. I’ll take pictures of everything and post them. Lots of help on here, thank you all !!
