we have a Whitfield pellet stove 20 FS-2. Lately when we turn it on, it will not only be a little slow to start, it will emit a heavy white smoke outside... Often we don't notice, being inside, however I can start to tell because it will struggle to light and when it does, it pushes out a puff of smoke into the room then burns quite hot. We've had the fire sept called by neighbors who thought there was a fire. Our thought was that we need to clean out the exhaust, but, we can't seem to disconnect the elbow outside the house, it has screws but won't come off. So
1. Is all the smoke a result of built up spot in the pipes/exhaust?
2. Are the exterior exhaust pipes supposed to come apart for cleaning? If so, do we strong arm it? Hubby is threatening to cut it!
Thanks![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks
