Hi,
I was wondering if anyone could share their thoughts on whether we should go with the Econburn gasification boiler over the less expensive and longer burn time TC 500 (or other similar boilers)?. We are looking at the brand new model of the TC 500 with the 130 gallon water jacket (which helps eliminate the need for the a thermal storage tank). We live in an old, small house. Last year we used about 740 gallons of oil. We have been heavily investigating the different gasification boilers and had it narrowed down tot he Econoburn. The trouble is we have very little room in our basement for a giant water storage tank. Our plan is to build a porch/room add on off of the side of our house that can be accessed through our side door for the actual boiler(it would be attached to the house and insulated). We would vent through a metal chimney through the ceiling of the bump out. This bump out would connect to our existing system through pipes into the basement (sits right above it). Anyway when all is said and done, the Thermal control has a burn time of 12-15 hours and is about 76% efficient while the Econburn has a much shorter burn time (8 hours or less when running on low) and would require an expensive (as far as I can tell) tank in the basement to make load time less inconvenient. Meanwhile, we are looking at a difference of about $5,000.00 initial cost. My question is does it always make sense in all cases that wood gasification is the best option where we have such an old house with a small basement? Also, if you think the non-gasifier boiler makes sense for us, do you have other models you recommend. We are trying to heat about 1500 square feet. We have a pretty new Buderis oil boiler in the basement and right now a combination of radiators and baseboard. Thanks for any help or suggestions.
