slaughter1600 said:ok on setting 4/5 the auger is running 8 seconds on 5 seconds off. The auger is attached to the motor by a pin going through the center of the shaft, so no slippage there. I looked up the tube and put a wire up there and moved it all around and it diddnt feel like anything was bridged. Im going to contac the lady again and make shure no one changed the board,motor, or anything else. This is frustrating.
buildingmaint said:Where is the selector switch set ? If the former owner used a stat and now your not using one, you might need to set it on manual, my old control board is c-e-401/1rpm.Be sure and let us know what or if you get your stove to run ok. We all like lots of info.
thes are a little on the long side from what my dad says next time ill look around more before i buy.
Agreed. Better pellet and Baffle plates that are coming from Breckwell.. You'll be in much better shape, once you slow the air flow going out of the house.slaughter1600 said:to bad i bought a whole tonthes are a little on the long side from what my dad says next time ill look around more before i buy.
Also you could have gotten a batch of pellets that are not the best of quality.
slaughter1600 said:Im useing curran Wood pellets. When I cleaned it I did remove them doors and cleaned out the back area good. The fire looks good to me(but i never had a pellet stove before) I know the pot is always near empty when new pellets feed in. and when they drop down I get alot of fly ash.
kinsman stoves said:I have heard of a few people saying they are not getting heat fromtheir Big E. I have searched the globe and located on of these. It is next to my desk at the store and I have been playing with it for over a week. The temp output is very low, the exhaust temp is high and it eats pellets like crazy. As of right now I have spoken to Breckwell Tech about this. I also spoke to Pellet and guess who has been more help to me? I am still attempting to locate the problem of this unit. I do have another post or two out there on this issue.
Eric
SmokeyTheBear said:Ah, yes, choice words.
Might not do anything but one sure feels better having vented.
There is a lot of crud on the market, bent this, corroding that, screeching bearings, rusting stainless etc... sure must be nice being in the repair business and working one's hind quarters off.
Is there any money in that?
