Are you getting 15+hrs when operating on s lower setting?On high my max burn time was 4-5 hours. On 3 the room that it is in is over 80°. On low it will be 75-77.
Lopi Rockport
Blaze King Ashford 25
Lopi Rockport
What? So he’s installed it temporarily until a solution is found?That was my initial thought! Curious if you could shed more light on that. The guy I bought it from measured incorrectly and the insert sticks out almost 2" which might give me enough room to be able to operate it.
would it be fine to just stuff it with rock wool vs a block plate?I would add a blockoff plate. It still won't meet BK's recommendations but it should work fine, on an interior chimney especially. The goal is to keep the top of the flue above 250F.
Theres a member who had to put a damper on his insert and he came up with a pretty clever solution, I think he had a clydesdale if that helps with a search. I was going to do it with mine but decided to switch to a different free stander.That was my initial thought! Curious if you could shed more light on that. The guy I bought it from measured incorrectly and the insert sticks out almost 2" which might give me enough room to be able to operate it.
Rotary cleaners go right past pipe dampers@bholler has rigged up insert dampers with an operating linkage through the surround. (How do you sweep that?)
I doubt the problem is due to an uninsulated liner although it should be insulated. It is probably a combo of no blockoff plate and not knowing the stove yet.My first post....
I'm incredibly disappointed with my brand new Blaze King Asford insert. The stove's burn time at best is maybe 5 hours ( my understanding it should be 15-20 hours), the fan on high is equivalent to low on my Harman Accentra & Napolean 1402 (yes I have 3 stoves) & frankly has a hard time heating up the 350 sq. ft room it's in. I feel like I purchased a total lemon! My two other stoves burn incredibly well and I paid a fraction of what the BK cost me. The dealer came over and said my problem is due to a noninsulated liner. I don't believe it. It's a interior chimney. Thoughts?
Dont you think a 32 foot liner and wood at 25% would be the place to start?I doubt the problem is due to an uninsulated liner although it should be insulated. It is probably a combo of no blockoff plate and not knowing the stove yet.
Nah, we're troubleshooting, the more opinions the better chance of solving the problem.I could be asked to remove my foot from my mouth if need be Should be interesting to see what he works out.
I take your word for it and order some kiln dried wood, $380/cord! Hopefully that's the cure. I'll keep you posted.My princess insert ran like two different stoves if I burned wood at 25% compared to <20. That's a long liner, that's going to cut way down on burn times unless you can find a way to operate a damper.
At 32ft of non insulated liner op should have plenty of drafting if op wraps liner it will improve more draft needing a damper if ever the wind picks up and is bk approved Question does the op have a top plate at chimney top to create dead air space thus no wind tunnel to help promote 125 degree from the back of the insulated (insert)to dead air space. Yes wrap the liner and try dryer wood but be carful dryer wood create faster burn rate and hotter stove temperature.
curious to hear how to install a damper. Also curious to hear people's experiences using a BK insert with a 30'+ liner?Rotary cleaners go right past pipe dampers
