Csst said:Yea everytime i run the stove i always open the front door clean it up with a shop vac open the bottom part clean the MESS of ashes thats in there (hopefully that will change) and also take out the ash tray inside clean the inside and around it witha shop vac and also pull both levers in and out to let all the tons of ashes fall and clean it all up and fire the unit back up again... Does this sound right to you?
Also you think its safe to run it tonight and sleep at night or you think im better off waiting til morning so i can fire it up and monitor it better?
I should have mention too when i was burning the flame seemed very tall and orange in color also?
I don't have any of the manuals for your stove so I have no idea about where things are that need to be cleaned.
But the flame should be yellow/orange tending towards yellow with a tinge of blue just above the pellets, it should not be a blowtorch or tall angry orange with black tips.
The primary air control for your stove is that damper you adjusted using the pencil. You may have to play with that to get the best burn.
It will be critical that your OAK not be blocked and that you keep the venting clean.
There should be a section in the installation manual that talks about how to adjust the damper.
